Throttle adjustment
Gday ladies and gents, it’s been I while since I’ve posted. Anyway I hope you doing well and living life and riding fast. Well im wondering if anyone can help with the best way to get rid of the play in my throttle as it’s just not cool/safe the way it is. I have about 5-6 mm of travel from throttle off to throttle opening. And help on the best/easiest way would be greatly appreciated cheers people. Keep the rubber side down |
If it just needs a minor adjustment, you can use the upper adjuster at the handlebar. Just loosen the locknut and turn the adjuster. If it doesn't adjust far enough, you'll have to prop up the tank and make the adjustment at the lower adjuster between the carbs. It should the rearmost of the two cables
Hope that helps |
That helps me a lot mr slap and Thank you. How’s you bike coming song? |
Making progress. Paint and body at about 95% but I need decals and got bogged down waiting for new pilot screws. Hopefully get her in rideable (if not complete) shape by father's day
