A TECKEY QUESTION ...
Old Jan 16, 2008 | 03:32 PM
John933's Avatar
Default A TECKEY QUESTION ...
I've got a question in the teckey section ... Any one like to have a shot at it ???
Question ???
John933
Old Jan 17, 2008 | 06:32 AM
Shadow's Avatar
Default RE: A TECKEY QUESTION ...
Well ?
Old Jan 17, 2008 | 08:39 AM
Abacus's Avatar
Hi john.
You still at that winter project of yours?
I thought she would be well finished by now.
No suggestions to your tech question, and the manual pics are as clear as mud.
Old Jan 20, 2008 | 09:48 AM
TimBucTwo's Avatar
When I click on the link I can see that the original seal is still under the old race. The old seal is missing the rubber that is needed to seal the bearing. Every bike that I have worked on has the seals on the outside of the head tube. Did you replace the old race? You need to as it does not look healthy. I can see in the photo that you have a new race and seal. The oldrace is a bitch to get off. When you get it off, remove the old seal.
When you reassemble the bike, put the new seal on just like the old seal and then the race. The new seal goes on first with rubber up and then the race. The race needs to be fully seated in the down position against the race.
To remove stubborn races, I have used a die grinder and chisel to split the race to remove it.
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
