synthetic oil, true or false???
#32
RE: synthetic oil, true or false???
I haven't confirmed this, but the reason I've heard you can not switch back to normal oil after you've used synth for a long period of time is, the synth oil does some thing to the engine gaskets. When you switch back to dino oil, after a while, you're gaskets will be shot. Not sure if it's true it not but that's exactly what happened to the head gaskets in my camaro.
#33
ORIGINAL: cr cbr
#35
#36
Synthetics have low foaming. Foaming while not good for the engine does reduce noise. I chop and change from synthetic to dino all the time depending on what is on special. Mostly its synthetic, but sometimes my cheap source isn't available and I get dino. With the low intervals the bike doesnt really care which I use.
#37
#38
