True or False??
Old Jun 7, 2010 | 10:04 PM
prowheelie92's Avatar
Default True or False??
alright so i was talking to one of my friend which has an f4i. just talking and randomly we started talking bout extended swingarm. he told me if you get a extended swingarm you get more torque. i asked him why and he said because of the longer chain. and i said thats not possible unless you change the gear ratio. what do you think the truth is
Old Jun 7, 2010 | 10:48 PM
heyitsmelam's Avatar
if anything you lose the geometry of the bike thus screwing up lean angles and handling.
Old Jun 7, 2010 | 11:02 PM
ef-fo-aye's Avatar
probably bc you can put more power down faster bc you wont wheelie on take off
Old Jun 8, 2010 | 12:13 AM
kowen1208's Avatar
Due to an increase in unsprung weight, you would see a slight (possibly negligible) loss in rear wheel power. However, you're able to put more power to the ground. A longer swing arm means the center of gravity is further forward from the rear wheel than a stock bike, thus is take more to lift the front. The limiting factor for acceleration on sport bikes is largely its ability to keep the front wheel down.
Old Jun 8, 2010 | 12:15 AM
bwayers's Avatar
your friend is wrong
the length of chain has no bearing on the amount of torque your bike has, it just means you won't wheelie as easily and can accelerate harder in the first few gears
if you dynoed a bike before and after an extended swingarm installation with the same sprockets on it you'd get the same results
Old Jun 8, 2010 | 04:48 AM
Jrzy Goat's Avatar
False.
Like others have said, you'll just be able to launch the bike quicker.
Old Jun 8, 2010 | 06:00 AM
thanks guys
Old Jun 8, 2010 | 08:19 AM
NateDieselF4i's Avatar
But more importantly I don't think it looks very good - and thats what this is all about isn't it?
Old Jun 8, 2010 | 08:30 AM
redzintimidator's Avatar
Torque has to do with the moment about the axis of rotation, therefore the only thing that would differ the torque would be different size sprockets, and different size tires.
Old Jun 8, 2010 | 01:56 PM
na i dont think it looks good either we just started talking about swingarms out of nowhere
