starting issues update
Old Apr 10, 2010 | 07:38 AM
Shadow's Avatar
Good news, I hope. I didn't know the flange thingy was a separate part - shows you, learn a new thing every day.
BTW I persuaded my damper to work by adding another cupped washer - tight as hell to get it in, but works very well. Maybe just a normal washer would work too - I'm told it will. You need a big bench vice and use it to squish the extra washer in.............
Let me know how you get on
Always a pleasure to help......
02 CASE, ALTERNATOR
31133-MS2-611 001 $828.33 YOUR PRICE $564.92
http://www.mrcycles.com/fiche_sectio...1991&fveh=3021
I'd suggest you take it apart again and have it welded by someone who knows composite metal welding.
Much cheaper.............or buy one on e-Bay.
Old Apr 11, 2010 | 04:31 AM
grimreaper's Avatar
that is what i did with the damper, put a washer in and this solved the starting issue. i think that is next avenue however, getting the existing case repaired either with a compound epoxy adhesive or plastic metal. it basically only has to sealed so that oil cannot escape then the problem will be fixed.
thanks for the help
Old Apr 11, 2010 | 05:21 PM
Sprock's Avatar
thanks for the help
JB Weld man , on that intermediate casing,believe it's available in the UK too
......it's real good stuff and can take heat and pressure like ya wouldn't believe
Waldo125
Sep 19, 2011 05:11 PM
thegatekeeper14
Jul 11, 2009 02:32 PM
R Dub
Mar 22, 2009 08:08 PM
crbnfibr
Oct 27, 2008 09:21 PM
808 cbr f4
Aug 20, 2008 03:59 AM
