split lower tranny case?
i have the engine out, oil pan pulled, all bolts around the case pulled, clutch, magneto etc... how do i go about actually getting the case off? there are the bolts on the main but i didn't know if i should pull them too? help me please my project needs a breakthrough soon before it takes the wind out of my sails
Have you downloaded the workshop manual for your model? You can find it in 'Workshop Manuals' they are very helpful. Also, this section is for showing How to do jobs not for asking how to be done. I am sure a moderator will see this and put it in the right section so you can get more answers to your prob.
I've split mine several times & never used a pry bar. The cases are metal to metal with only a small amount of sealer between. From memory there are a couple of places to use a bar but be very careful. Also a good way to remove the sealer once apart is not to scrape the faces but use a suade brush. It's a fine brass brush used for suade clothes. Should be able to pick one up from the boot maker/repairer.
