speedometer gearbox
Old Mar 14, 2007 | 10:06 PM
SStreak's Avatar
Default speedometer gearbox
Has anyone had any experience or luck finding a speedometer gearbox for a 90 model cbr? My speedometer is good, my cable is good, and my gearbox won't turn. The bike shop couldn't find it on their parts lists or blow-ups. Any ideas or suggestions would be appreciated. Thanks....
Old Mar 15, 2007 | 12:01 AM
Chuck Norris's Avatar
Default RE: speedometer gearbox
Does your cable run to the front wheel or to the front sprocket? If it's the front sprocket... there is one on ebay for a '91(still will fit yours) for starting bid of $9.99. I've bought stuff from that seller. So it's a pretty good deal. If it goes to the front anything off of an older model will work.
Old Mar 15, 2007 | 12:32 AM
SStreak's Avatar
Thanks for the info. It runs to the front sprocket. I'll check out E-bay. Thanks again.
Old Mar 15, 2007 | 10:48 AM
It looks like it's item #16 on the E-11 Fische for the 1990 CBR 1000F. It's also included with the item #4 Cover Assembly. Hope this helps.
Old Mar 15, 2007 | 09:50 PM
SStreak's Avatar
You're right. It is #16. It is the speedometer joint. Turns out this was the culprit. The gearbox itself is built in to the sprocket cover and cannot be repaired. One has to buy a new cover if the gearbox goes out. Thanks for the reply.
91f22
F2 Tech
Jun 27, 2012 12:17 PM
Swe_man
Apr 29, 2011 04:19 PM
apophis
F2 Tech
Sep 10, 2010 08:01 PM
jrm03
Jul 8, 2007 07:31 PM
walsh41
Aug 4, 2006 03:24 AM
