Regulator/rectifier question
Old May 12, 2008 | 07:37 PM
bigape's Avatar
Default Regulator/rectifier question
I got an aftermarket reg/rec for my '90 1000F. My plan was to cut off the melted connector and use spade connectors and fresh wires to fix the bike. Problem is, my Dad cut if off before I got to it and now does not remember which color went to which connector. Does anyone have a good picture of the connector with the wires still in it that they could forward to me?
Thanks. I really want to get her back on the road.
Old May 12, 2008 | 10:18 PM
Naga_Thai's Avatar
Default RE: Regulator/rectifier question
Photo here ....
See page 14-8 on this paper here for wire diagram with colours to connectors.
http://tinyurl.com/663ras
[IMG]local://upfiles/25866/81B2DA4029DE4852B3FDF26D25F3FA79.jpg[/IMG]
[IMG]local://upfiles/25866/FCC74BD1EB6742618C3713B71D446DD4.jpg[/IMG]
Old May 12, 2008 | 11:40 PM
Shadow's Avatar
Have a look in the manual - there's a diagram in the electrical section which shows you exactly which wires go where......
Y B W Y yelow Blue white Yellow
R/W Y red/white yellow
That's looking at the plug. The three yellows can go to any yellow connector - field coils
Old May 13, 2008 | 08:49 AM
bigape's Avatar
Thanks for the pics, I will try it this evening.
By the way Shadow, I do have the Honda service manual. The diagram does show the wire colors and how they relate to the coils in the reg/rec, but the book does not specify the pinout. It is a 2-dimensional line drawing. Considering there are 4 connetions on the top row and 2 on the bottom, I wanted a pic to take the guess work out of it.
Old May 13, 2008 | 09:26 AM
Shadow's Avatar
My diagram was looking into the pins. The red/white pin is slightly wider than the others.Hope this helps
Old May 14, 2008 | 08:39 PM
bigape's Avatar
Thanks a lot guys. I got the reg/rec wired and installed today. With the motor running, she is putting out 13.89 VDC.
Thanksagain for the help.
Old May 14, 2008 | 08:40 PM
bigape's Avatar
Now, if I could only find an upper fairing...
pacojoseph
Apr 15, 2013 02:51 AM
cbrgirl82
Jul 31, 2012 02:04 PM
ajzcamaro
Jun 18, 2011 12:40 PM
CBR1987Yellow
Nov 8, 2007 02:09 PM
CBR600F4i2005
Jul 14, 2007 10:39 PM
