Rectifier
Old Jun 18, 2011 | 05:48 AM
Shadow's Avatar
Depends if your current one is "cooked" or not. It would be a temp fix to get you mobile until one can arrive from Electrex. Nothing worse than not being able to ride.................
Old Jun 19, 2011 | 07:18 AM
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
Robbie,
If you decide to go for the Electrex unit, bring 2 in, I'll buy one to put aside for a rainy day
TK
Old Jun 20, 2011 | 10:50 AM
grendl's Avatar
Question on the electrex . It looks like the original is different from the electrex as pertains to the wiring. The electrex has a pigtail where the original looks like a female plug? opinions on that or am I not seeing it correctly? Mine is fine now , but I do a lot of solo away from normal highways. Thinking to replace as this seems to be a high usage part..
Old Jun 20, 2011 | 11:04 AM
Shadow's Avatar
It comes with a male and female plug Grendl and all connectors (brass). Easy to change on the side of the road if you have to - take 5 mins. Problem is you'll generally only know if you have a problem when the bike stops (ask me how I know) and these bikes won't push start too well I know this to be true
Bolts have to be longer too due to thickness of heatsink but it still fits fine on the frame where it should.
Old Jun 20, 2011 | 04:04 PM
robbiebgraham's Avatar
I'm pretty sure mine is stuffed because I have had to top the battery up a couple of time over the last few months. I just noticed white battery acid on the main stand the other day and it's coming from the battery overflow!!!!! So, I guessed the battery is boiling dry!
TK, a new one from the UK might have to wait for a wile as it will cost around $200 landed, bit much at the moment!!
I will check out a secondhand one for now.
Cheers and thanks guys for the input.
Old Jun 21, 2011 | 12:01 AM
jarvid's Avatar
Welcome Crew
Don't forget to flush with lots of hot water where ever the battery acid leaked!
Old Jun 21, 2011 | 12:07 AM
Good point and must do this!!!!
Old Jun 21, 2011 | 02:28 AM
jarvid's Avatar
Welcome Crew
Mix a bit of bicarb in the water to help neutralize the acid, do it soon or you could get all kinds of nasty things start to happen, stuffed paint, electrical shorts etc...
Old Jun 21, 2011 | 03:11 AM
kiwi TK's Avatar
Oops, I read that as $95, that exchange rate is right b1tch aint it?
Old Jun 25, 2011 | 02:09 AM
Naga_Thai's Avatar
Robbie & TK,
FYI - Saw this @ $50. Cant vouch for it. I have Electrex one. See my link in signature for details.
Rectifier Regulator Honda CB750 CB750F CB1000 CBR1000F (eBay item 130537601695 end time 24-Jul-11 14:36:43 AEST) : Cars, Bikes, Boats
OOP'S - ROBBIE - JUST REALISED YOU HAVE 1987 MODEL - THIS IS FOR Honda CBR1000F (90-96).
