Rear fender
It came out better than I thought after starting. I was hoping for an easy plug and play fit. But found myself hacking/cutting and drilling with time constraints (work, daylight and weather). No garage working outside ☀️☔️⚡️🌙💨⛅️.
I'm posting from my phone and I can't figure how to post more than one photo per post. Sorry! View under tail section.
So thanks Jarvid,
I wish I could have recorded the process to benefit others but it was a rushed project and I was figuring it out as I went.
One key point: the battery boxes are also different and complicates the process. The fender attaches to the battery box. I chose to keep my stock box, which necessitated some way to attach the front end of the new fender. I thought that was better than replacing it.
From there it's trimming (thoughtfully/carefully) enough of the sides from the fender, for it to tuck up inside the frame rails into the right position, and attach the back end.
Hope that helps.
Hope that helps.
