Rattling engine noise on a 1000F after replacement of Cam Chain
Old 07-09-2018, 02:50 AM
SamkFL's Avatar
Unhappy Rattling engine noise on a 1000F after replacement of Cam Chain
Hi all,
I am Sam from Kenya and have a 1990 CBR 1000F. I had a rattling sound in my engine a few months back and i bought a new cam chain and had it replaced. the problem is the rattling sound did not dissapear and of late is becoming worse.
Kindly advise on what could be happening and what should be done to resolve this sound.
Regards
Samuel Gurrion
Old 07-10-2018, 04:29 AM
jarvid's Avatar
Welcome Crew
Did you replace the cam chain tensioner at the same time as the chain? If you did not, that will be the problem.
Old 07-10-2018, 09:22 AM
Wolkersdorfer2's Avatar
My 88 600f also makes a rattle noise at very light throttle at lower rpm (4k or less). Does not make any bad noise at 1/4 or more throttle. I am hoping i dont need to replace the chain as the bike only has 15k on it. Following thread for update.
Old 07-10-2018, 05:27 PM
tentacleslap's Avatar
Confirm valve adjustment. If they are loose, they'll rattle, but if they're too tight, they'll destroy the cams
It's normal for the chain to rattle when cold, but it should quiet down once the bike is warm
Old 07-11-2018, 09:34 AM
TimBucTwo's Avatar
Sam, I'm also thinking cam chain tensioner. What type oil are you using?
You need to use good MC rated oil and change it regularly.
Old 08-14-2018, 02:42 AM
SamkFL's Avatar
Hi. Thanks for this. I did not replace the CAM chain tensioner. Let me plan to do that then
. Thanks again.
Regards Gurrion
Old 08-14-2018, 02:44 AM
SamkFL's Avatar
i use mineral oil 20W50 and change it regularly. say after every 2000 - 3000kms. Thanks for your input.
Old 08-14-2018, 02:46 AM
SamkFL's Avatar
i will confirm valve adjustment.
It is rattling even when warm.
Regards
Gurrion
3v1lj03
1000F Videos
16
08-12-2012 09:22 AM
chrstbren@aol.com
11-02-2011 12:41 PM
WillyG
01-07-2009 07:54 AM
redcbr
07-12-2007 09:32 AM
poppy
08-31-2006 06:05 AM
Quick Reply: Rattling engine noise on a 1000F after replacement of Cam Chain
