Question on triple tree "free play" rotation
Old Sep 7, 2008 | 09:09 AM
paul6585's Avatar
Default Question on triple tree "free play" rotation
'90 1000F.I am checking the steering head bearings with the forks (and tire) off the bike. As the triple tree rotates, there seems to be a flat spot in the bearings at the point wherethe triple tree is positioned straight ahead. There is also some (very little) resistance in movement of the triple tree that is probably not noticable when the weight of forks and tire are installed.
Can anyone provide me with some insight? Are these two issues part of the design and thereforenormal operationof the triple tree or am in need of new bearings? I have replaced steering head bearings on my dirt bike and it does not operate in the same manner. (no flat spot and very little resistance&gt
Old Sep 7, 2008 | 11:22 AM
Shadow's Avatar
Default RE: Question on triple tree "free play" rotation
1 There shouldn't be a flat spot, to my knowledge.I too have a 90 1000F
If you've stripped it that far replace the bearings with the tapered type - I think Timbucto has the part numbers. There are writeups on the forum, done very well by the members.
Also look at www.mrcycles.com for part numbers and prices.
I'd NEVER put it back together without replacing them, if you can afford it (even if you can't)
supersnake83
Feb 1, 2009 02:31 PM
pacojoseph
Jun 3, 2008 12:50 PM
pacojoseph
Jun 2, 2008 11:42 PM
slimmyslim1420
Sep 23, 2007 04:19 AM
bluej511
Sep 10, 2007 09:58 PM
