Question for CCT Gurus
Old Dec 11, 2017 | 12:04 PM
Red Baron's Avatar
Question Question for CCT Gurus
Doing soon the CCT on my 1988 with a new CCT from '90-'96 model.
There are 2 parts that are not on the '88 model diagram:
Chain Oiler Guide
Chain Oiler Plate
My questions, are they needed and will they fit without modifications to the cylinder head?
Thanks in advance for your kind response.
Old Dec 11, 2017 | 12:23 PM
tentacleslap's Avatar
Bolts right on, just that easy. I found one on my 87 so it's probably a common retrofit
Old Dec 11, 2017 | 12:40 PM
Red Baron's Avatar
Thumbs up
A BIG THANKS to you!!!
One more question, do they require 2 bolts or are they attached to the 2 front bolts of the CCT?
Old Dec 11, 2017 | 12:50 PM
Hawkwind2016's Avatar
Hi Red,
No doubt someone will have done this and can advise you from first hand experience.
But, in the meantime, I would strongly advise you read this 'How To', by the late Michael Parks (God rest his soul), if you haven't already done so.
https://cbrforum.com/forum/how-tos-8...cement-103362/
Old Dec 11, 2017 | 02:07 PM
They're held in place by two of the head nuts. They designed the oiler guide to direct oil down into the cct chamber, if that makes sense. Installation would just be a matter of removing the two head nuts, tossing the washers, installing the oil guide piece with the plate on top, then rebolting
Once you have the cams out it should be a bit more obvious where they go cause there's really only one place they will fit, and I don't think it would be possible to put them in backwards
The writeup Hawkwind shared has some good pictures of what it'll look like, so that's probably a good place to start
Old Dec 11, 2017 | 04:41 PM
Red Baron's Avatar
Thumbs up
Thanks again to both. I will read faithfully and watch the videos and report back once I do this summer.
Old Dec 12, 2017 | 02:00 AM
If you've got the time Red, you could always wait for the next exciting episode of Tentacleslap's engine rebuild video series.
https://cbrforum.com/forum/how-tos-8...r1000f-156490/
I do not exaggerate, when I say, one of the greatest contributions to the CBR1000F forum.
Old Dec 12, 2017 | 10:36 AM
Red Baron's Avatar
Thumbs up
Yes, agree 100% with those videos.
Old Dec 13, 2017 | 11:18 AM
Well shucks - but I will say that I'm no expert on these bikes. I'm still pretty fresh to mine, and engines are all pretty similar when it comes down to it. From poking around the forum I'll say there's a lot of members with an encyclopedic knowledge of these bikes and all their various quirks
Hawkwind is definitely one of those folks, along with a lot of the other OG's. I lean on their experience quite a bit, since tuning/troubleshooting isn't my strong suit
Old Dec 16, 2017 | 07:08 AM
GronkFries's Avatar
I look forward to cracking mine open, especially with all the fabulous info around here.
Oscar Foxtrot
Feb 18, 2013 07:49 AM
DarrylS
Feb 9, 2013 06:06 PM
bluerrchik
Mar 14, 2010 12:47 PM
Lepperfish
Jan 8, 2010 11:34 AM
Hayden06F4i
Sep 16, 2008 04:37 PM
