Power rating
Old 09-18-2005, 01:31 AM
MarkR's Avatar
Default Power rating
Did the 1000f get a power upgrade in 1993, I found a referance on the web that said the 92' models and before had 98.4kw and 100.7 after?
Old 09-18-2005, 01:57 PM
slowpoke's Avatar
Default RE: Power rating
The carbs were changed in 1993, but I don't know if anything else engine-wise was changed. When Cycle magazine (May, 1991) tested the CBR 1000F, their dyno made 107.9 HP at 9,500 and 64.9 lb/ft at 8,000. It made over 60 lb/ft from 6,000 to 10,000. I don't have any tests of the 1993 or later.
Old 09-18-2005, 07:42 PM
MarkR's Avatar
I found this
Max. Power Output 135PS/9,500rpm (DIN) (99kW/9,500min-1)
G-type 98PS/9,000rpm (DIN) (72kW/9,000min-1)
Max. Torque 10.6kg-m/8,500rpm (DIN) (104Nm/8,500min-1)
G-type 9kg-m/6,250rpm (DIN) (88Nm/6,250min-1)
What is a G-Type and how do you know if you have one?
Nitro
05-05-2008 06:31 AM
sportracer07
03-20-2008 01:40 AM
stephen4785
06-21-2007 12:51 PM
oismail
06-04-2006 01:12 AM
RTmotive
09-08-2005 09:10 AM
Quick Reply: Power rating
