Possible Causes For Throttle Stick
Old Feb 23, 2010 | 02:55 AM
Aussie Johnno's Avatar
Ride of the Year ... Just Ask The Boys
Default Possible Causes For Throttle Stick
Hello Inmates,
I have noticed that after the bike warms up the throttle seems to stick, let me explain.
rather than the revs dropping down between each gear change the revs seem to hang.
possible causes
- throttle cables?
- Carbie slides?
Any others?
For all you Victorian gentlemen - I rode the Great Ocean road a couple of weeks ago, the missus gave me a sunday off, and the rest is history, what an absolute hoot. These bikes just hang on to the road for dear life.
Aussie Johnno
Old Feb 23, 2010 | 08:30 AM
malbojah's Avatar
Thinking (hurts, ow! quit it!): Throttle grip has slid against the bar end weight, tweaked handlebar, gummed up throttle cables, gummed up carb spring, air leak past carb boots...
that's all I can come up with after just waking up
Old Feb 23, 2010 | 08:59 AM
bicklebok's Avatar
I think Malbojah has about summed it up. If you cant find the obvious with the grip or cables, the intake/vacuum leak would certainly be suspicious.
Old Feb 26, 2010 | 01:50 AM
Thank You for the responses, but i think i have isolated the problem.
I made sure the cables were running smooth and they were, bar end weight was out of the way.
It seems that where the throttle body turns inside the switch control it is getting stuck, and i can not work out what is causing it.
I have had it apart many times but every time i bolt it back together, it just jams up again.
The bike is in the garage, i am inside having a drink, i will think about it tomorrow
Aussie Johnno
Old Feb 26, 2010 | 04:59 AM
steve c's Avatar
Hi. Has the bike ever been down on it`s right side? The reason I ask is, mine was doing exactly the same thing.It had been dropped prior to me buying it. The handle bar had a very slight kink or bend in it right where the throttle body tightens up. When it was loosened off it was fine, but when it was tightened again it was stiff. So I got another one off flea bay. its ok now. Hope this helps.
Old Feb 26, 2010 | 08:40 AM
malbojah's Avatar
mine did the same as steves, so I got a set of vfr bars
CorruptFile
Aug 1, 2019 07:06 PM
boru
Dec 29, 2012 11:16 PM
lordexpectation
Dec 19, 2011 04:22 PM
CaNsA
Jul 1, 2010 09:42 PM
aaron1085
Jul 13, 2007 07:12 AM
