Please Help Me
Old Sep 8, 2011 | 10:14 AM
  #62
TimBucTwo's Avatar
On topic , we really need someone to do a step by step detailed (successful fuel pump removal !) thread in the " How Too's "
This issue rears its head near every month here and never seems to be addressed quite fully in any one thread ? !
From what I remember, the end result is that they get removed. Why put $$$ into something that is not needed.
And like CBR1988 says, the air box needs to be replaced after carb work. These bikes run lean due to EPA laws and removing them open up a can of worms.
Sorry about the paint thing, just biding time waiting to hear back from BlackSubmarine.
Old Sep 8, 2011 | 06:51 PM
  #63
BlackSubmarine's Avatar
Hey all. I found the fuel pump pretty easily the other day. Took it off, taped up the wires, etc. I think the bike may have the original fuel pump on it... it's just like the one in the manual and is pretty sizable (almost 2" in diameter). I'll go get a smaller Marine one like in those pics. Maybe that will allow me to store the thing better.
As to the "How To" sticky, I'd be willing to take pictures for everyone, but I don't have anything stock in that area unfortunately (except the filter...)
Thanks again
Old Sep 8, 2011 | 08:37 PM
  #64
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Originally Posted by CBR1988
Hey:
You do not need to remove the airbox, that is why I mentioned it was in the same location then as now. The filter fits into the area where the box is on that side and is a little tight but works just fine there. I remove the airbox long after I had removed the fuel pump and had the box on it till I ran my FCR carbs, with a different engine in this bike.
Do not remove the airboxe unless you have plenty of time to spend on a dyno to get it tuned right or tons of time to spend on road tuning and jetting/rejetting & other carb adjustments. The stock airbox works just fine on this model and only little performance gains are had getting rid of it, but other mods must take place for those to be realized or a driveabilty issue will be had and a performance decrease will be seen.
1. So locate the fuel pump by following the fuel tap hose from the tank to the round device with 2 hoses and a wired plug.
2. Disconnect wire plug and tape off or heat shink over the side remaining on the motorcycle , remove hose from tap to pump, and if putting in new fuel injection line on and inline fiter, also remove fuel line from pump to carbs. Suggest you purchase at least 18" of at least 5/16" inner diameter fuel injection hose & clamps, and same size Marine type filter if running a mostly stock bike (has modded Exhaust).
3. Run new fuel inj line from fuel tap to new inline filter and then from inline filter out to the carb bank, tighten all clamps.
4. You are completly done, now enjoy a fuel pump problem free bike.
The reason for fuel injection line is, it is better quality and has a higher burst pressure and will last longer, use matching fuel inj clamps as they clamp better. The reason for a Marine filter is they have inexpensive replacement inner filters, and filter well without restricting flow and easily available world wide.
My pic above has 3/8 line and filter as I have a large bore kit, hotter cams and a bigger valve ported head that runs with Nitrous on occasion, that goes in this bike from time to time.
Dub
Hey
Classic whats wrong with that 1-4?
Dub
Old Sep 9, 2011 | 02:59 AM
  #66
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
I don't think Sprock has checked in today Steve, I see the trans-gender avatar still survives.
Old Sep 9, 2011 | 05:45 AM
  #68
kiwi TK's Avatar
Is it possible that someone could be so very clever with geeky kind of computer stuff that the avatar and username would appear to be all normal at Sprocks house and only display any differently to everyone else in the world?
Now that would be very clever.
Old Sep 9, 2011 | 06:12 AM
  #70
kiwi TK's Avatar
Just glad it's not me, you're clearly not nervous Steve. How about the Trout?
