My starting problem
#52
CyberTrip, have you adjusted shim and bucket valve lash before? If not we can help you through it.
I don't know how I missed the rest of this thread. TBT was right on with the valves and I'm glad you got it sorted Cybertrip.
I think the bolt may come out with an extractor. I didn't put much torque on it. My torque bar was set to 7ft-lbs and it twisted off before it even clicked.
I swear, it's like they're made of cheap plastic.
They're easy to get out, though. The one I was able to use a little screw extractor on. The worse of the two, I just drilled into the center of the bolt and then pounded a slightly larger torx driver into the hole and screwed it right out. I thought it was pretty ingenious.
The bolts are the same size as the ones that hold the fairings on if you need a quick fix. Otherwise, they are M6 I believe.
#53
Here's the video!
http://www.youtube.com/watch?v=8murdiMAHDg
As you can see, I did something bad that morning!
#55
#58
