Micron exhaust . . . .need jettin?
After fitting the MICRON exhaust its leaking at the headers ive takenit of and fitted new gaskets but its still leaking![sm=headbang.gif]gonna take it off again and re assemble using some silicon Hylomar.
ANYWAY my question is anyone else fitted a complete Micron exhaust? if so did/does it need rejetting?
RE: Micron exhaust . . . .need jettin?
Try it with the stock setup-- take it on a ride-- if it doesnt return quickly to idle when revved in neutral, crank out the pilot jets a half turn. Try again.
During your ride if it coughs under a gradual WOT, then move up one size on your mains. Then try again. If it is just the exhaust system and no intake changes, the stock needles will probably be fine. I recommend the Dynojet kit-- just because it is all i use at our shop.
