low speed wobble
Old Apr 11, 2008 | 07:15 AM
ahawkins's Avatar
Default low speed wobble
I have a 95 and at low speed (under 50) if I let go of the bars it shakes like a speed wobble. Wondered if you could let me know the first and easiest place to look to rectify this.
Thanks, Al
Old Apr 11, 2008 | 07:20 AM
MarkR's Avatar
Default RE: low speed wobble
I would check the wheel balance, warp wheel or rotors
Old Apr 11, 2008 | 07:26 AM
weekendrider's Avatar
mine shakes when the tyre starts to wear on the out sides best thing to do is dont let go of the bars unless you wont to scare your self.
Old Apr 11, 2008 | 08:14 AM
malbojah's Avatar
Check tire pressure, the for cupping of the front wheel (happens on Dunlops a lot more often than other tires I've used)
Old Apr 11, 2008 | 10:59 AM
paul6585's Avatar
Iagree with above posts.In my expperiencethe steeringwobble increases as the tire wears.It also wouldn't hurt to check the front wheel bearings asI have burned through two sets in about 20k miles. This is a heavy bike.
To check the bearings: 1.)lift front tire off ground, rotate tire and listen for excessive noise. 2.)Hold forks/steering in placeand try to shake tire sid to side. You are looking for excessive play between axle and wheel.
Old Apr 11, 2008 | 11:13 AM
CosmoBob's Avatar
Rear tyre wear is a common reason to wobbling steering wheel, even more so than front tyre wear, in my very limited experience.
Old Apr 11, 2008 | 11:31 AM
Shadow's Avatar
If you hear a click under braking from the front, I would add steering head bearings to your checklist as well.
Old Apr 11, 2008 | 03:20 PM
ahawkins's Avatar
The click is a definite so I will start there.
Thanks guys
Old Apr 11, 2008 | 07:35 PM
Jeff B's Avatar
ORIGINAL: malbojah
+1
My front D220 on my 96 has some cupping to it and does this also. The head bearings are good and I check my tire pressure before each ride. I'll never own another set of D220's.
itlnF4I
Oct 29, 2013 03:15 AM
subyman1440
Jul 9, 2012 01:09 AM
itlnF4I
Oct 15, 2011 09:49 AM
hawkwind
Aug 2, 2009 05:25 PM
abramj
Oct 15, 2007 06:56 AM
