intermittent headlight
Old Sep 5, 2008 | 06:09 PM
fast1000f's Avatar
Default intermittent headlight
have an 87 hurricane 1000 with a headlight that comes and and goes. i suspect its a loose wire but i thought mabye someone has had this problem also? ideas, suggestions? thanks
Old Sep 5, 2008 | 07:18 PM
BayAreaRider's Avatar
Default RE: intermittent headlight
fri.funny
someone threw a modulator on?[sm=lol.gif]
Old Sep 5, 2008 | 11:14 PM
Shadow's Avatar
sat.funny - sloooooooooow modulator, B A R !
Probably just a fuse is corroded or you have an intermittent earth. Clean the fuse, then try running a second earth wire, see if it helps.
Old Sep 5, 2008 | 11:19 PM
Does it affect both the high beam and low beam? If it affects both, then I'd suspect the wiring between the starter switch and the dimmer switch. If it's only afftecting high or low, the I'd be looking from the dimmer switch to the headlight.
Old Sep 6, 2008 | 12:07 PM
fast1000f's Avatar
does it on high and low beam. the wiring goes from the starter switch to the dimmer?
good to know, ill check there, and the fuses also, i suspected a bad ground wire myself. thanks
Old Sep 6, 2008 | 12:17 PM
Shadow's Avatar
If you need a wiring diagram, shout......
Old Sep 8, 2008 | 11:28 AM
samron333's Avatar
Registered Users
I just went through the same problem on my 87. I took my switch apart and cleaned the contacts and have not had a problem since, just have to be careful, there is a tiny ball bearing that likes to fly out when it is taken apart.
Old Sep 8, 2008 | 12:49 PM
Harry_T_Hamster's Avatar
Are you sure your not just blinking your eyes?
*RUNS AWAY*
Old Sep 8, 2008 | 08:03 PM
fast1000f's Avatar
funny stuff harry, problem lies in the starter switch, so i shall dismantle and clean, hopefully
rlnelson5
Oct 14, 2013 09:08 PM
K9K9
Apr 14, 2013 05:35 PM
TechGirl1414
Dec 11, 2011 07:50 AM
Backwoods
Nov 28, 2011 08:38 PM
bentf3
Oct 6, 2006 11:06 AM
