info please
Old Mar 6, 2010 | 11:31 AM
scorpion2010's Avatar
Default info please
hi thought i would get stuck in and clean my carbs on my 1000f .while i had carbs off , thought would check valves ,tried to get plugs out so engine would turn over easier ,plug spanner i have wouldnt fit thought they were same size as my cbr600f .apparently not.what size plug spanner do i need .also on petcock there is 2 small outlets one on side for vacum pipe what is the one on bottom for ? there is no pipe on this one .thanks in advance for info.
Old Mar 6, 2010 | 01:15 PM
Shadow's Avatar
Can't help with plug spanner size
Ignore the one without pipe on it..............
Old Mar 6, 2010 | 01:56 PM
Dadarob's Avatar
Hi scorpion, i have just bought a plug spanner for my 93 1000f last week.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
It is a 12mm long reach, it worked perfectly & only 3 days from order to door, or
you maybe able to get one in a shop local to you. Hope this helps.
Old Mar 7, 2010 | 05:13 AM
Shadow's Avatar
The other hose is only an overflow or something - mine has one but it just hangs down by the rear wheel.
MaxTO
May 16, 2012 07:01 PM
Sand.Man
Mar 22, 2012 03:03 PM
210Ryder
Jun 14, 2010 01:54 PM
studdermonkey
Aug 27, 2007 07:48 AM
