ill running 87 need help
i need help with the old girl, she is not running like her old self, she was running fine and the next thing i knew she was running like she was out of gas, put fresh gas in and she still ran like crap, went home took tank off to see if fuel pump was functioning it was. if any one has any ideas give me a shout please or if someone is in the los angeles area/ torrance maybe you can give me a hand with the old girl. thanx much the forum is very informitive.[X(][:@]
just out of interest, have you checked the ignition coils? if its struggling for fuel then this could be one to check. you will need to check one coil at a time to see if you are getting a spark at the plugs and if so, to confirm that you have the correct amps. good luck
