Ignition advancer, does it work
Old Sep 25, 2006 | 03:31 PM
Oelhunden's Avatar
Default Ignition advancer, does it work
Will a ignition advancer give more power on our bikes ?
Old Sep 25, 2006 | 07:52 PM
R1000's Avatar
Default RE: Ignition advancer, does it work
An ignition advancer should give a snappier low/midrange throttle response and something in the region of 2 extra horsepower, if you are willing to increase the risk for pinging/detonation. To handle that risk, one could go up a step in fuel octane rating and also avoid giving full throttle on low rpm's on high gears. Going down one tooth front will also help to prevent detonation.
I believe it’s worth trying if you don’t expect too much and keep the information above in mind. A better way to increase the throttle response and power is of course to put a full exhaust system on and rejet the carbs with a dynojet kit. That will obviously cost much more and also lower the mileage.
Old Sep 25, 2006 | 09:11 PM
slowpoke's Avatar
Like R1000 says, you may have detonation, especially at sea level. But an ignition advancer may work pretty well at a mile high though. I will have to ask around and see if anyone here has installed one.
l0st1
Sep 2, 2009 06:59 PM
Ayres_08
May 27, 2008 09:43 PM
Takahashi
Jan 18, 2008 08:48 AM
camoweasel
Nov 26, 2007 11:37 PM
big10donjuan
Feb 2, 2007 01:15 AM
