Hopefully a very helpful post for everyone
Old Mar 30, 2013 | 10:51 PM
Insan3Nightmare's Avatar
Default Hopefully a very helpful post for everyone
Ok so recently my bike would bog like it was out of gas, I made a post how it might be where I was running low on gas, but something never seemed quite right.
Last week I left work, it bogged and had to trailer it home. I was replacing the engine and jets in the carbs that weekend anyways. So I cleaned the bowls, installed jets and shims, (new engine) and rode it around the block, just fine, second lap it bogged and died again. I pulled and clean the bowls and little jets that are in front of the intake to no avail at least 3-5 times. It would idle but not run. As I googled it I discovered this is a issue people often can't figure out. So I thought "well there is nothing left to clean....except the slides!" so I pull the top off, and the diaphragm, and low and behold the is dirt all under there when it sucks air in and put for the movement of the sliders. it sucks air through that little plastic whatchacallit next to the coils to the top of the carbs
I clean the trash out and she purrs and revs like a champ.
Basically my sliders wouldn't go up to alow airflow. So when I gave it some throttle, it would choke it with too much fuel and no air. So if you ever have a chance give it a glance. Might help your response too. Surprised I missed the dirt when I shimmed the needle, but the top of the carb is the last place I'd look for trash.
Also the carbs had 32000 miles on them
Hope this help!
Old Mar 31, 2013 | 01:19 PM
slowpoke's Avatar
Good detective work. Most people don't know that the throttle cable only controls the throttle plate, which is on the engine side of the carb. Above idle, the throttle plate adjusts the amount of fuel admitted to the engine that was mixed together at the piston/needle and needle seat.
The piston/needle is controlled by the difference in engine vacuum and air pressure, which could be very slight. If the throttle is pulled open, no fuel or air will get into the engine if the plastic piston/needle doesn't move up because it and or the piston bore is dirty.
My 79 Suzuki has the old carburetors where the throttle cable is attached directly to the piston/needle. Very easy to bog the engine if you are too ham-fisted with the throttle. And of course, the emissions thing.
Old Apr 1, 2013 | 02:10 AM
Shadow's Avatar
Good tip !
Old Apr 7, 2013 | 07:00 AM
wheelnut's Avatar
Welcome Crew
very handy to know
therabbit
Aug 8, 2021 10:42 AM
Blackspike
Nov 27, 2016 08:15 AM
RojerLockless
Feb 16, 2016 07:08 AM
t-mac5826
Aug 10, 2011 04:47 PM
S-lo-rider
Jun 16, 2009 12:34 PM
