Head Light Bulb Replacement for 1990
Old Aug 3, 2007 | 05:51 PM
DarkStar9's Avatar
Default Head Light Bulb Replacement for 1990
Hi All,
I am looking for a replacement bulbs for my 1990 CBR 1000f. I would like to go with an after-market bulbs on the lines of a PIAA or equivelent without having to drop serious cash for swap out of 2 bulbs. Anyone have links and or part numbers? Thank you in Advance!
Ed
Old Aug 3, 2007 | 06:08 PM
ArTravlR's Avatar
Default RE: Head Light Bulb Replacement for 1990
I bought some H4 bulbs from Wally World for about $7.00 each. I used H4 bulb shims found at the following vendors:
http://www.casporttouring.com/store/...Code=replabulb
http://www.sporttouringusa.com/www/h4rings.htm
ArTravlR
LoweST Cheapo Arkansas
1990 CBR1000F
2002 ST1100A2 STovokor
2005 VFR800A5 Interprize
Old Aug 3, 2007 | 08:24 PM
dad's Avatar
dad
It is also possible to replace the stock bulbs with H-4's without using adapters. If you break off the two outboard tabs from the H-4 bulbs the socket design will still center the bulb on its perimeter and the single vertical tab will orient the bulb in the correct vertical position.
Again, retain the center tab, the vertical one. Break off the two outboard tabs.
Old Aug 3, 2007 | 08:28 PM
Stray Cat's Avatar
The shim also keeps the bulb from being the correct distance from the reflector to project the beam in the right pattern. I haven't used one on the CBR, but that is the main complaint from the VFR people.
Old Aug 3, 2007 | 11:34 PM
BayAreaRider's Avatar
I found a set on eBay that fit and work nice! ~$30/ pair
www.EuroDezigns.com
Old Aug 4, 2007 | 09:07 AM
TimBucTwo's Avatar
You can get the proper standoff by doing the following:
(1) Flatten the upper tab at 12 o-clock with pliers to widen it. The old bulb is a little wider.
(2) Push the two **** at 6 o-clock back flat against the body.
(3) Cut a piece of wire close hanger the width of the body diameter and place it behind the body at 6 o-clock and bend the tabs at 4 o-clock and 7 o-clock back with pliers locking the wire in place.
Insert the bulb like the old one and you will have the proper standoff and full brightness at the coast of a coat hanger.
This is how I do mine.
Old Aug 4, 2007 | 04:52 PM
mikekop's Avatar
October 2009 ROTM
Or you just live in Europe and use standard H4 without the need to fiddle with adapters and breaking off tabs...
Old Aug 10, 2007 | 10:26 AM
CR500R's Avatar
TimBucTwo, thanks a million for the sweet tip! I did what you wrote about last night and got a regular H4 bulb in and working perfectly. No needing to spend the $11-12 for "shims". While they are a good idea at a decent price, for a measly piece of coathanger, your solution works brilliantly, thanks again.
Krux
Jan 18, 2010 08:11 PM
FruntRangeBkr
Jul 31, 2008 01:56 PM
oodayvidoo
Sep 5, 2007 01:35 PM
bosta84
Apr 26, 2007 01:07 PM
jerrad
Jun 7, 2006 10:59 AM
