h.o.w. 2 split engine case
Old Jul 16, 2008 | 05:27 PM
simtech's Avatar
Default h.o.w. 2 split engine case
forum issue sorry,
couldnt find just starter clutch replacement in the manuals
see below
Old Jul 16, 2008 | 05:32 PM
simtech's Avatar
Default RE: h.o.w. 2 split engine case
bad rattle from the starter clutch after a kickback during start,
how hard is it to split the bottom case and change the clutch ?
Anyone got a 'How To' put together ?
Thanks
Old Jul 16, 2008 | 05:33 PM
simtech's Avatar
just found the starter clutch, on the alternator parts blowup,
So is it maybe I can pull the alternator to change this ?
Gotta be an easier way than splitting the case !
Old Jul 17, 2008 | 01:12 AM
Shadow's Avatar
The only guy I know who has been able to repair his starter clutch without splitting the casings is KASKA. He did a write-up on removing his stator unit, and tells you how.
PM him or look through his posts, may save you a LOAD of work !
You may have just messed up the tensioner.............?
Old Jul 17, 2008 | 05:29 AM
bluebeard's Avatar
Are you sure it's the starter clutch. After a big kickback it's normally the tensioner that goes. That means split the cases.
Old Jul 17, 2008 | 06:37 PM
simtech's Avatar
no not sure for definite of starter clutch, have not disassembled anything yet.
Definite the sound is coming from between starter and alternator in the top part of case,
by using stethiscope.
With further research found the writeup of Vulcanman and how he turned bike on its side,
I may give that a shot when I get a day off, right now working 7 days a wk 10 hrs a day.
Old Jul 18, 2008 | 07:36 AM
MarkR's Avatar
Only 70 hours a week, that's a bit slack - I can't get it under 100.
Old Jul 18, 2008 | 08:05 AM
Shadow's Avatar
Lookup Kaska - see post from 5-12-08
Well i have done it now. The starter clutch is fixed. For now at least And it cost few beers
Pictures are seen in here http://www.zone.ee/kaspar10/CBR/
Old Jul 18, 2008 | 06:50 PM
simtech's Avatar
great pics, thanks alot
Jordan Fonte
Jul 28, 2018 01:39 AM
booradley!
Sep 20, 2011 10:25 AM
Lotsokids
Aug 16, 2008 01:26 PM
kentuckydiesel
Jun 30, 2008 12:55 AM
meatpopsicle
Sep 18, 2007 07:10 AM
