Glue, now that's a question!!
Old Aug 1, 2005 | 03:59 AM
Firefox11's Avatar
Default Glue, now that's a question!!
I have a small crack in the rear fairing by the tail light.. I need to get some glue that will hold it together, does anyone know a glue that will hold that plastic together well?? Its not a "stress" area persay, but vibration does like to cause brittle glues to crack ya know??
I'm definately taking suggestions!! Thanks..
Old Aug 1, 2005 | 06:35 PM
SILVERBIRD's Avatar
Default RE: Glue, now that's a question!!
ANCHOR-TITE EPOXY SYSTEMS. IT COMES IN A DUAL SYRINGE AND ONE SIDE IS BLUE AND THE OTHER CLEAR. THERE ARE 3 OR 4 DIFFERENT TYPES. MAKE SURE YOU GET THE ONE THATS SAYS FLEXIBLE. I USE THIS STUFF AND SEEMS TO WORK EXCELLENT FOR ME.
Old Aug 2, 2005 | 05:26 PM
brownhornet's Avatar
The epoxy mentioned befor is the best thing I've found. On my 90' I have one of the front turn signal mounts welded together with that stuff and it has lasted for a long time.
Old Aug 3, 2005 | 01:51 PM
Firefox11's Avatar
The funny thing is, I think I have seen that stuff before... I'm gonna have to go and get myself a tube.. If its blue, then I will definately want to be careful and not let any oooze to the surface or it will show color! Not cool... I will have to becareful. How long does it take for the epoxy to cure??? Is it available at hardware stores, or motorcycle shops only?
Old Aug 22, 2005 | 11:41 AM
ozrider's Avatar
I have tried flexible drying epoxy glue and seems to set pretty well - long term probably will depend on the stresses on the particular part you are applying the epoxy to. I have also discovered a website talking about abs cement which is supposed to work better like a weld.
TimBucTwo
The Hurricane Saloon
Jan 17, 2015 01:30 PM
dyracuse
Feb 8, 2010 09:13 PM
crookedeyemotocross
May 14, 2006 11:40 PM
jg
Apr 18, 2006 10:31 AM
Red Baron
Mar 14, 2006 09:19 PM
