fork disassembly help
Old Apr 27, 2013 | 02:23 PM
swoop4321's Avatar
Default fork disassembly help
Hi everyone. I'm changing out the fork seals on my 88 hurricane and I have the fork apart but i can't figure out how to get the damper out of the tube, i can't see any fasteners holding it in. Do i need a special tool?
Old Apr 27, 2013 | 02:49 PM
hawkwind's Avatar
Did you remove the allen head bolt at the bottom of the fork?
Also you might find the workshop manuals to be of help here :-
Workshop Manuals - CBR Forum - Enthusiast forums for Honda CBR Owners
and here :-
https://cbrforum.com/forum/workshop-...anuals-101343/
Old Apr 27, 2013 | 04:24 PM
swoop4321's Avatar
Yes, I've taken out the bolt and i have the manual but the diagram isn't quite the same. It just looks like there are seals at each end and i can't reach to remove them.
Old Apr 27, 2013 | 06:53 PM
swoop4321's Avatar
Okay, so i got the manual from a different forum and it must be for another year (out doesn't specify) so the damper just came out the other direction. There's still some parts in the tube though and the manual in hawkwind's post doesn't say how they come out, do they come out?
Btw, thanks for the link hawkwind!
Old Apr 27, 2013 | 08:45 PM
swoop4321's Avatar
Old Apr 28, 2013 | 02:45 AM
hawkwind's Avatar
What year bike do you have Swoop? 87/88 forks are different to the later ones?
Have you actually separated the chrome stanchion(slider) from the lower fork tube?
Old Apr 28, 2013 | 11:54 AM
swoop4321's Avatar
It's an 88. Yeah, the forks are completely apart except for those three or four pieces at the end that the damper sits on.
Old Apr 28, 2013 | 02:59 PM
hawkwind's Avatar
Unfortunately my bike is a '91 so has the later fork design and though I have rebuilt my forks, I'm not familiar with the early design.
I'm sure someone else with the MK1 will be along to help soon.
I'll have a look in the manual in the mean time, see if I can figure something out for you.
Old Apr 28, 2013 | 03:13 PM
swoop4321's Avatar
Thanks man.
Here's what I'm working with (this is inside the stanchion):
Attached Thumbnails fork disassembly help-cam00021.jpg   fork disassembly help-cam00024.jpg
Old Apr 28, 2013 | 03:49 PM
Sprock's Avatar
Normal way you do this routine is
First - allen bolt undone
then
tops off and springs out
then
pull like bejaysus in a ratcheting
motion on the fork tubes with the
result being the seals and the whole
innerds comes right out in one motion
pretty much.
And no Hawk it's not whole lot different than
the 90
if the inner piece is still stuck in there
I'd screw the hex back in and tap it gently
until it is free.
Your first photo has me wonder why there is
a seal still in there ? !- as it's one of the first things
out and one of the last to go back on almost.
