Fit alternate R/R to '97 1000F
Old 02-19-2008, 08:56 AM
GILL's Avatar
Default RE: Fit alternate R/R to '97 1000F
It's huge! I guess with that mammoth heat-sink like that, you wont have to worry about it overheating. It looks like the old Ford regulators from the 80's
I was wondering why there is a spare fuse in top of the battery? Are there fuses located elsewhere other than the left front fuse box up front?
  #32
Old 02-19-2008, 09:08 AM
Daniel_ARG's Avatar
yep that's the spare fuse for the pulser coil (I think it's that one), wich is behind the right hand side cover.
  #33
Old 02-20-2008, 12:47 PM
Shadow's Avatar
Yep, main fuse ....-30 A I think, situated by the starter solenoid, inside a rubber housing
  #34
Old 04-21-2008, 05:16 AM
Naga_Thai's Avatar
Danial
Many thanks for your work and details on this. I need to do the same. Where did you buy the R/R? do you have a web link please?
  #35
Old 04-21-2008, 08:43 AM
Daniel_ARG's Avatar
Bought it from a local manufacturer, got the link posted before but here it is:
http://www.espel.com.ar/index.php?setidioma=en
Site is dead now, might be maintenance so check later.
  #36
Old 04-21-2008, 10:28 AM
Shadow's Avatar
When I cook 'em, they STAY cooked !! Pics of my last one, huge heatsink and all.
All the black areas are burnt areas.....hmmmmmmm !![:@][:@]
[IMG]local://upfiles/22903/E9D107A45E1F42FC97F330E20EB63D17.jpg[/IMG]
  #37
Old 04-21-2008, 07:49 PM
Naga_Thai's Avatar
Danial
Thanks for your picture - looks great.
Can you please list the colour connections you used from bike loom to this regulator. eg
Bike loom wire = yellow to Regulator wire ???????
Bike loom wire = red/white to Regulator wire ???????
Bike loom wire =black to Regulator wire ???????
Bike loom wire =white to Regulator wire ???????
Bike loom wire =Grren earthto Regulator wire ???????
TIA
  #38
Old 04-21-2008, 07:53 PM
Naga_Thai's Avatar
Shadow1
After you cooked this aftermarket RR what make did you use for replacement?
Did you find out why this on fried?
TIA
  #39
Old 04-21-2008, 11:56 PM
Shadow's Avatar
We THINK it was burnt field coil in the stator.Ohms resistance was up at 3.5 instead of 2.6 which will fry a reg/rec over time....it was under guarantee so they gave me another one (1 year from www.electrex.uk)6 months on off road stuff. Daniel's one in Argentina(Espel) gives 2 years - excellent !
And on the wiring issue, the colours are matched by same colours from the reg rec
3 Yellow - stator
red/white - power to battery
Green - to chassis etc etc.
If the colours don't match, be careful....
  #40
Old 04-30-2008, 01:22 AM
Naga_Thai's Avatar
Having been faced with this issue I researched and made this following conclusion. The facts that enabled me to make this conclusion is contained in the pdf file as linked. Hope this helps others and save you the time it took me to do the research separating the facts from the "beliefs".
HONDAREGULATORRECTIFIER –
Replacement - CB-750, CB-1000, CBR-1000F, ST-1100.
(SHINDINGEN # SH261-12).
This paper looks at the options when replacing the following;
Hondaregulatorrectifier Assy 31600-MS2-601 (Shindingen # SH261-12) that fits;
· CB-750 Nighthawk 750 1991-2004
· CB-1000 1994-1995
· CBR-1000F (Hurricane) 1990-1996
· ST-1100 1991-1995
· ST-1100a ABS 1992-1995.
WARNING: This paper is only of “Reference Use” to any other bike as the Regulator / Rectifier used here is very different to others.
Disclaimer / Attributes: The contents of this paper has been plagiarised from many sources for the benefit of all who face this issue. Web references/credits are given where I practically can.
Special thanks: to Shadow1 and Daniel_ARG of WWW.CBRFORUM.COM
Attached: Honda CBR1000F Service Manual Charging System Details.
[/align]
Problem
The Honda Regulator/Rectifier (R/R) as above fails more than most and has to be replaced. What is the best solution?
Issues
Why is the Honda R/R above different from most other R/Rs?
Honda R/R fails more than most – should I keep paying for this model when it is a known problem?
Is there an alternate from another bike I can use?
What aftermarket solutions are there?
Do they have better reliability?
Are they cheaper?[/ol]
Are there other solutions? Do they work?[/ol]
Solution
Buy
New type RR23 - more reliable than the smaller unfinned version. AU $160.00 Delivered to Australia.
Electrex World Limited
Tel: **44 (0)1491 682369
Fax: **44(0)1491 682286
www.electrexworld.co.uk
[hr]
[/align]
PDF PAPER HERE.....
http://tinyurl.com/663ras
OR
http://cid-52a693f944c3508f.skydrive.live.com/browse.aspx/HONDA%20REGULATOR%20RECTIFIER%20-%20Replacement%20%e2%80%93%20for%20CB-750,%20CBR-1000,%20CBR-1000F,%20ST-1100.%20|5SHINDINGEN%20|3%20SH261-12|6.pdf
[font=arial][color=#810081][s
Quick Reply: Fit alternate R/R to '97 1000F
