Fairing plastic
Old 05-03-2008 | 11:04 AM
DRam's Avatar
Very Honorable Most Senior Member :)
Default Fairing plastic
Does anyone out there know what type of plastic was used on the '91 fairings? I haven't found a glue yet that will hold.
Old 05-03-2008 | 11:29 AM
kaska's Avatar
Default RE: Fairing plastic
my 89 is abs plastic i dont see any reason why yours should be any different.
What kind of clue you used?
I have used epo based clues and they still hold.
You could also try epo resin and some glass reinforcing making it a composite
Old 05-03-2008 | 11:48 AM
BayAreaRider's Avatar
http://plastex.home.att.net/
Try this stuff!
I found it from a mention on this site, got some and have repaired cracks and missing tabs perfectly!
Good Luck.
Old 05-03-2008 | 06:21 PM
DRam's Avatar
Thanks guys. The Plaxtex site looks good. I'll order some and try it. I'm also going to check around here forglue meant for ABS.
Old 05-04-2008 | 02:20 PM
Dean0's Avatar
I used Permapoxy (5 min plastic weld ) on mine and it held up great.
www.permatex.com
can be sanded and finished just like the oem plastic after it has set
lichercbr
04-24-2009 10:08 PM
Blackrr1
01-18-2008 01:41 PM
matty
08-10-2007 02:54 PM
SkinnyJ
06-23-2006 01:01 AM
Quick Reply: Fairing plastic
