Plastic Fairing Clips
Old Aug 9, 2007 | 11:40 AM
matty's Avatar
Default Plastic Fairing Clips
I broke a few of these and need some new ones. Couldnt find any on ebay, and did a google search with not much luck.
Am i searching for the right name?
Thanks!
Old Aug 9, 2007 | 12:07 PM
eyesky2002's Avatar
Default RE: Plastic Fairing Clips
Do you mean the little pop in ones that have the phillips head in them?
Here is a complete fairing bolt kit that looks like it has them in them, but $45.00 blows. What I did was go to Ace hardware and got the little pop in type lirk for door panels, little harder to get out so put them where you have access (underside of bike where side fairings meet) and put the good ones in the tighter spots.
http://cgi.ebay.com/ebaymotors/HONDA...spagenameZWDVW
Old Aug 9, 2007 | 12:33 PM
matty's Avatar
No that's not the ones. It's the clips that hold the plastics together. For example my undertail is missing a couple.
The ones that you need to pull the plastic centre out before the clip will come out.
Old Aug 9, 2007 | 11:42 PM
txsmainevent's Avatar
are you talkin about the plastic rivets or what? we need alot more of a description, usually the undertails use plastic rivets. now if ur talkin bout an actual plastic piece breakin off the part then thats a issue
Old Aug 10, 2007 | 07:28 AM
matty's Avatar
Yes sir, that's exactly what I'm talking about.
thanks
Old Aug 10, 2007 | 07:58 AM
eyesky2002's Avatar
I checked at the local shop yester why I was wishing for KX450F. $1.53 each
Old Aug 10, 2007 | 08:56 AM
matty's Avatar
Jeez, i never even thought about checking with the dealer. I'm working way to much lately.... my brain is fried.
thanks guys
Old Aug 10, 2007 | 09:49 AM
gearhead's Avatar
Ace hardware has some that work, they are the same type of plastic rivet that you can reuse. They are like 50 cents each or something. Never by anything from the stealership if you can avoid it.
Old Aug 10, 2007 | 01:54 PM
hey matty plastic rivets arent uncommon at all, you can pretty much find them at most bolt stores. they are not some special part that you would need to order from the dealership/stealership. just search around for them and u can also type in plastic rivets on ebay and im sure u will get tons of items.
HagBard
Sep 19, 2010 10:40 AM
lichercbr
Apr 24, 2009 09:08 PM
DRam
May 4, 2008 01:20 PM
azmotopete
Sep 1, 2006 01:16 AM
