Exhaust Baffle?
Old Nov 19, 2009 | 03:10 AM
Aussie Johnno's Avatar
Ride of the Year ... Just Ask The Boys
Default Exhaust Baffle?
Hi All,
My exhaust has been drilled out by the previous owner, by drilled out i mean 8 small holes in a circle around the main outlet. Is there a way of packing the exhausat to make it more quiet?
Aussie Johnno
Old Nov 19, 2009 | 07:49 AM
bluebeard's Avatar
My old stock ones were a little louder that normal but I don't know why. I put a 4-2-1 straight through on with a reverse cone & 1 3/4 pipe in the middle to tune the power & I now have a lot less drama in traffic. I'll never go to a quiet exhaust again. Mine isn't loud but people can hear me coming.
The stock muffler is rather thick stainless steel & all spot welded. The end caps can be removed by drilling out the 3 welds as I did to mine. Then weld a nut inside & just a gutter bolt painted black to put them back on. No one even notices that it's been done as they sit flat & don't attract the eye. There is a bloke here in Adelaide that builds motorcycle exhausts. Surely theres one there in Melbourne. Ask the bike shops. Someone would know???
Old Nov 19, 2009 | 09:49 AM
dietDrThunder's Avatar
The idea posted above by Classic re: using screws is the best way to accomplish what you're asking. If that doesn't do it, you're only out a buck or two.
Old Nov 19, 2009 | 08:50 PM
kilgoretrout's Avatar
Administrator - Retired
Yep, I'd say using screws would be easiest to do. However, you could always weld them shut, too. That's what I planned to do if I ever wanted to go back, but I like a little noise.
Hmm... I wonder if the PO drilled the holes after reading about it on this forum?? LOL..
Old Nov 19, 2009 | 09:04 PM
datru's Avatar
Looks like the previous owner drilled out the rivets and just never put in new rivets. A gasket seal can also be used around the edges too if its leaking.
Old Nov 19, 2009 | 11:15 PM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Cool
Sprocket has four holes in his and he uses "plugs" in his. He takes them out when he rides around and puts them in when he rides to work. He has it up on youtube, so you can hear and see the difference.
Old Nov 19, 2009 | 11:56 PM
No rivets, prolly just holes in the endcap.
And I don't see why sprock would bother with the plugs unless he's a wiener.
Old Nov 20, 2009 | 12:37 PM
Sprock's Avatar
Ya know what Trout you simple minded misfit ..............
take that striped bass ya caught and dump it in your panties
cuz it's the only wiener you'll ever be able to point to.....
But yeah mine has 3 5/8 inch holes drilled in each can. I use hex
bolts to close 'em when I'm riding down to Massachusetts ( noise
laws) and take them out for riding about locally here ....not as
strict on Noise Ordinances in this Town.
Best of both worlds really
I know I have some vids on here from July ............let me go find
Yep ............found it and the thread
https://cbrforum.com/forum/showthrea...ghlight=baffle
here also is Classic's vid of his from a good while back , and Indy's before he
put his new V & H last week.
http://www.youtube.com/watch?v=_97zB...eature=related
http://www.youtube.com/watch?v=9xeMn...eature=related
olden mgroin
Sep 21, 2009 11:59 AM
A4wheelin
Aug 4, 2007 08:21 PM
CantBeatRidin600f4i
Sep 27, 2006 07:23 PM
laybac
May 16, 2006 09:19 PM
ride_002000
May 9, 2006 04:25 PM
