fitting a Garmin Nuvi
Old Nov 16, 2009 | 01:55 PM
Shadow's Avatar
Default fitting a Garmin Nuvi
I know some of you have done it - I need pics of the bracket you used - Sprocketman................?
I also found a bracket from HongKong which will fit on bikes with bars, like the KLR, etc and may be of interest to those of you that ride other makes.........really cheap at $3..........
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
Old Nov 16, 2009 | 02:09 PM
Sprock's Avatar
Default garmin mount
...............yep gimme a few minutes
You Need These ............and you unscrew the little screw that
goes up the shank and replace with an appropriate lenght screw
and washer to attach to whatever mount you use
Old Nov 16, 2009 | 02:48 PM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Thumbs up
I know it is not the braket but Sproket shows. If you need a picture I will go take one from the side. I also found that after you ride alittle bit with it. I used some glue to help it from not rotating.
Old Nov 17, 2009 | 12:52 AM
Shadow's Avatar
Thanks guys ! I found that "jewel" of a post about how to use the shaft down the centre of the headstock, and all is now easy !
I have threadbar, washers nuts etc, and making a mount is easy from there on.
Yay !
I'll post up when the Garmin 350 is fitted and running.
Thanks again.
Old Nov 17, 2009 | 08:14 AM
Sprock's Avatar
Good deal .......look forward to seeing it
Now for a place for that walking stick
They say a fishing rod holder mount works
real good !!! hee hee hee
Old Nov 17, 2009 | 09:41 AM
Shadow's Avatar
You know exactly where you can put that walking stick, Sprocket ! (but then you may enjoy that ! ?)
Old Nov 17, 2009 | 12:30 PM
Sprock's Avatar
Figured you'd say something "lame" like that ......geddit ......LOL
Anyway back to business ......you mounting the GPS to the tank or the bars ??
Also
Here found you a nice one with an extra mirror for when ya have it
mounted on the bike, as I suggested
Old Nov 17, 2009 | 01:49 PM
Shadow's Avatar
Asshat I bought the machine from, tells me at the THIRD time of asking that the machine only has Europe maps...................useless to me, so cancelled the deal. I'll keep looking.
Mounting it through the headstock.
Old Nov 17, 2009 | 03:58 PM
Sprock's Avatar
Yep Headstock is the fastest simplest way.
Pete Garmin sells map updates by subscription from their website
direct loading into the Nuvi .............go check all that out first.
https://buy.garmin.com/shop/shop.do?pID=15535 this is an example
of a map for the Nuvi 265WT (the 265W) is a great deal with wider screen
cheap on E-bay.......buy it load map into it from online
I have NUMAPS LifeTime for my Nuvi 885T .......Maps and updates forever
Old Nov 17, 2009 | 04:08 PM
Thumbs up
That is a great deal, the lifetime. if you go just to buy the maps at bestbuy to download onto garmin is $99
