Engine Rebuild
Old Jan 23, 2007 | 06:12 AM
Trips's Avatar
Default Engine Rebuild
I am considering biting the bullet and doing a rebuild some time this year.
What I want to know is what are the thing that are really going to cost the big $$$.
Things like seal XXX thats costs a fortune.
I know about thing like the starter clutch & alternator dampener that won't be cheap.
But if anyone has done it before and got a list of the real expensive stuff it would be great.
Thanks
Rob
Old Jan 23, 2007 | 10:07 AM
R1000's Avatar
Default RE: Engine Rebuild
Here (in Sweden) it's by far cheaper to buy a completelow mileage engine than to do a complete enginerebuildon a high mileage unit.
Old Jan 23, 2007 | 10:21 AM
cbrmark's Avatar
What makes you think she needs a complete rebuild? If you dont mind my asking, how many kms has she done now?
Old Jan 23, 2007 | 07:05 PM
Trips's Avatar
Ahh she's started burning 2l of oil every 5000k. Plus I want a big bore kit Plus its usually after 100,000ks that the starter clutch goes and I might as well do a re-build while I am in there. Shifting is also getting harder & noisier despite replacing all the detent bits etc.
Old Jan 25, 2007 | 06:27 PM
collector's Avatar
Ok Rob. Pop up on david silver spares and see what you can find. A full gasket set here is £133.00 and o/s pistons are £20.00 each plus rings, also when you get your rebore done have your new valves seated as this will save time and money and the bearings in the box are £15.00 for the main and £20.00 for the needles then you've got the shells on the crank shaft for the pistons as well. Job lot, should set you back £600.00. But this should ease with doing most of the rebuild yourself. Let us know how you get on.
[sm=bounceybounce.gif]
DTownRunner
Jan 9, 2014 10:03 AM
hioc1098
Apr 20, 2013 02:08 PM
CSXfan
Mar 25, 2011 09:02 PM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
collector
Sep 4, 2007 03:10 PM
