electrical issue
electrical issue
O.K., here is a **** question, I just washed my 93 turned the key to the on position hit start button and heard a pop. Then the instrument cluster went dead. O.K. popped a fuse, right. Well I looked at everyone and they all look fine. Is there any "hidden" fuses tucked away somewhere? Or may it be something else?
Thanks, Matt
Thanks, Matt
My RR lights died one day So i pulled the fuse's & they looked solid , so started putting a meter on the lines which could be the fault , but still nothing up to the fuse box & then i put the multi to the fuse that looks 100% & it was "dead"?, but not showing break in the window, & this was the factory mini 10 amp blade fuse !!! All that pissing about for hours & hours ? & it was a fuse?!!!!. So i tossed all the factory fuses from the fuse box & replaced with the see through plastic on the whole fuse plastic casings, instead of those ones which only had a window & non see through plastic on the fuse sides. lesson learned!! In the end it only took me time by going around in circles over & over.
C.W
C.W
