?%#&%$E* remove a ?%&% screw
Old Nov 9, 2008 | 07:33 AM
DragonCBR's Avatar
Default ?%#&%$E* remove a ?%&% screw
My speedometer cable broke, the !#R%Y?&R screw that retains the cable cannot be remove,I tried a screw remover same problem,any ideas....I tried to warm it to get it unstock and unstock it same problem.
arrrrgh !@$#%&*
Old Nov 9, 2008 | 08:08 AM
Dean0's Avatar
Default RE: ?%#&%$E* remove a ?%&% screw
I usually try an Impact Screwdriver - the shock of the impact usually loosens most screws.
Only other option is going to be drilling it out with a smaller drill bit first.
Old Nov 9, 2008 | 11:58 AM
Griffin's Avatar
I've had good success with impact drivers.
Old Nov 9, 2008 | 01:17 PM
Shadow's Avatar
Maybe some penetrating oil like Q20 or similar, allow to stand a while, then a whack with the impact driver should do it, Carl.
Old Nov 9, 2008 | 04:27 PM
hawkwind's Avatar
Have you tried tightening it first ? This certainly works with old wood screws that are gunked up with old paint , and if the screw head is knackered turning the other way it should get more grip .
Old Nov 10, 2008 | 01:08 AM
ebinz88cane's Avatar
ORIGINAL: hawkwind
cautious not to strip the threads or break the head off... then your in deeper water than when you tried turning it the correct way.
Old Nov 10, 2008 | 01:10 PM
TimBucTwo's Avatar
My vote is for the impact driver.
I have to use one every time I remove that screw.
DON'T OVER TIGHTEN IT WHEN YOU PUT IT BACK.
When I reinstall it, I snug it up, not tight. I would rather loose it than have to drill it out the next time.
Old Nov 20, 2008 | 08:15 PM
Trips's Avatar
Try Loctite Freeze & Release
Old Mar 8, 2009 | 09:13 AM
DragonCBR's Avatar
Smile
I know this is and old one, just to prove that everything goes well when you use the right tools, i had purchase a screw remover when the threads on the head of the screw are stripped, did not work, since it was the end of the season i put everything away and let it sleep, meanwhile i had purchase a rotary tool and in there was a small cut off disk, well i used it to do a groove trough the screw to use a flat screwdriver, put the screwdriver and click came out, total time of operation 5 minutes!
Love those rotary tools you can do anything with those with very much precision...
so thought i would share the trick.
Have a good day!
Old Mar 8, 2009 | 09:29 AM
hawkwind's Avatar
Great going Dragon ! I know it's an old one too , but it's always nice to hear the final outcome , well done mate!
antatious
F2 Tech
Aug 23, 2010 05:31 PM
bigtim4
Jul 30, 2009 10:21 AM
cmorse
Jul 15, 2008 07:24 PM
mandosgreat
May 14, 2006 05:25 PM
