Drilling slides
Old Jun 15, 2013 | 12:28 PM
Sprock's Avatar
Default Drilling slides
It's a much discussed subject on a lot of Forums. Some jet kits come with
drill bits some don't. Some Jet outfits promote drilling slides , others warn
against it - saying once drilled you cannot go back - (which is BS all you do
is epoxy the drilled hole and re-drill a stock size)
Just wondering any one done it the their Hurricane ?
Anyone have opinions on the merits of doing it ?
Old Jun 15, 2013 | 09:22 PM
Bordo's Avatar
I don't even know what your talking about....lol.
Old Jun 15, 2013 | 09:57 PM
Sprock's Avatar
there's a little breather hole in each carb piston/slide Bordo that serves as a pressure
equalizer / regulator that dictates how quickly the diaphragm / slide / needles raise
or lower when you twist the throttle
Some say enlarging that hole can lead to quicker response time and by default better
throttle response - but then some say otherwise - just wondering if any "old heads"
here had tried it out.
Might get a set of used slides and give it a go to find out if this thread comes up zero.
Having rejetted my 90 last year I'm thinking she may benefit from this only one way
to know - someone has done it - or as I said give it a go myself
Old Jun 15, 2013 | 10:44 PM
Bordo's Avatar
No worries buddy. If I want a quicker response I either tell the wife she has put on a few kg this week or I get on the Blackbird.....
Old Jun 16, 2013 | 08:02 PM
TimBucTwo's Avatar
If it ain't broke.....
If its running fine I would leave it alone.
My thoughts are that if you go big bore you may benefit, just a guess.
I drilled the them on an MG and couldn't tell any difference.
Old Jun 18, 2013 | 04:57 AM
Sprock's Avatar
(UK) I would leave it alone.
That's the point, "if it's running fine"
It's maybe fine but it's not optimal !
An MG - well there's a lot of things one might not be able to readily
assess with one of those suckers
rdsii64
Feb 13, 2015 11:20 PM
upgradedcbr
Jan 14, 2013 10:20 PM
dagg92
F2 Tech
Jul 31, 2012 01:04 PM
egdcbr600rr
Apr 18, 2008 12:31 AM
beachaccord
May 9, 2006 03:53 AM
