Jet drilling...?
Old Jul 30, 2012 | 04:06 AM
dagg92's Avatar
Default Jet drilling...?
I was looking at jet kits recently, and while looking at them I realize they are literally just a bigger hole for 60 bucks...Can I just get the proper size drill bit and drill right through the main jets and pilot jets???
new exhaust is popping like crazy hinting the fuel ratio is off.
Old Jul 30, 2012 | 07:42 AM
JankCibberf2's Avatar
instead of being dumb and buying a jet kit, you could go buy single jets for 2 bucks a piece at local motorcycle shops, or even cheaper prolly online
Old Jul 30, 2012 | 11:04 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Like Jank said, you don't have to buy a kit to get jets, you just need Keihin round mains, and they can be bought individually in some spots, or at least in packs of four, which is what you need - the most I've ever paid is about $4 per jet.
For the record, if your bike is popping on deceleration, you typically don't adjust mains for that...how many "turns out" are your pilot screws currently set at? If it's popping on decel, you can turn out those 4 screws, in 1/4 turn increments, and possibly eliminate the issue there, that is, depending on how many rotations they are currently turned out.
Old Jul 30, 2012 | 04:46 PM
dagg92's Avatar
Wow what a rip-off, thanks for that info! I am unsure of the current pilot screw set, but I'm guessing it is stock because my old Yoshi pipe was popping also so I believe it was never tuned.
So turning the jets out means I should be turning the pilot jets counter clockwise, correct?
Old Jul 30, 2012 | 07:11 PM
sjona2011's Avatar
you can drill your current jets larger, there are charts that tell you what size drill bit to use for different jet sizes.
but unless you have an extra set of jets lying around then i wouldnt, if you mess up youll end up buying new ones anyway.
Old Jul 31, 2012 | 09:51 AM
JNSRacing's Avatar
Yes sir, lefty loosy get's you more fuel - you might turn all of them all the way in first, being careful to count the amount of turns it takes to get them seated fully - that way you'll know where they all started at, and you might find that they're all over the place anyway...you never know what the PO did to the carbs!!
Old Jul 31, 2012 | 01:04 PM
dagg92's Avatar
awesome thanks for the advice!
rdsii64
Feb 13, 2015 11:20 PM
Sprock
Jun 18, 2013 04:57 AM
upgradedcbr
Jan 14, 2013 10:20 PM
egdcbr600rr
Apr 18, 2008 12:31 AM
beachaccord
May 9, 2006 03:53 AM
