Originally Posted by ranchome
(Post 1113814)
I have a question along this same line.
At night my headlight dims at idle, brand new battery, 15v at 5000 rpm. I don't remember it being this way last year. Normal? Cause for concern? It's normal - it's also a good check to see that the battery is charging when the lights get brighter as you rev the bike. |
^ +1 and a reminder to keep moving.
My theory is when you insist on keeping a dead or dying battery in the bike
it first beats the hell out of the R/R and then the next down the line is the stator windings, once the R/R gets nicely cooked up first. Change your battery every 2 years (wet type) 3 1/2 years sealed AGM or GEL and the R/R will keep on going ....... is what I think. Anybidy think this makes sense ?? ....... or will Trouts bike go up in smoke soon enough (hopefully) :D |
These post have me paranoid on the R/R. I think I am going to order the electrex from the UK, that seems to be the way to go. Not having any problems but my rides are typically all day in the mountains around here - you can end up a long ways from anywhere. Of course pushing is not so much a problem,depending on which side of the mountain you are on :icon_nut:
Seriously, My bike has ~25 k on it and I notice I have to fill the 2 year old battery up occasionally, part of my pre-ride check. Now the question is related to having to re-wire the electrex in. Is there a how to on that? I'm good with my hands ,but figure there'll only be one chance to get it right with uncertain but prolly disastrous consequences. |
Originally Posted by Sprock
(Post 1113926)
[ ] B-Makes little sense [ ] C-Changing a perfectly good batteries is costly [ ] D-What in gods name has Trout done to you? (it would be funny however) [x] E-Both C and D apply grendl, there is a lot of info. Check the How To section first. |
It's really easy. First take a pic of your current wiring with your camera. Follow the colours as in the original plug unit. The yellow stator wires can be connected in any order to any 3 yellow wires from the R/R, so no problem. The earth wire goes to the frame. Red to red, black to black etc. You will need longer mounting bolts for the Electrex unit. It's quite a bit bigger due to the cooling fins. Takes about 15 mins and you're ready to go. :) |
Originally Posted by MadHattr059
(Post 1112198)
(my personal choice) the electrosport aftermarket replacement. www.electrosport.com
(Post 1114278)
Is this a direct plug in? It looks like it has the proper connection block and bolts directly on. I'd rather spend a little more $$$ for dependability and not be cutting into things.
Problem with mine, was that, when the R/R started failing, it toasted my bike's
connector. So what I did: Cut the connector off, added female bayonets to the ends of my harness wires, individually. I then used heat-shrink, over top of them, to insulate. It was simple after that, to plug each to it's respective spot in the R/R's connector. Here's a picture of the final result.... https://fbcdn-sphotos-a.akamaihd.net..._4859903_n.jpg Ern |
(Post 1114496)
Problem with mine, was that, when the R/R started failing, it toasted my bike's connector.
