doesn't sound good
Old 06-25-2008, 03:21 PM
Daniel.Hennessy@va.g's Avatar
Default doesn't sound good
My 87 cane started making what sounded like a way-rattley squeal which then got worse. Have you ever been hugged by a pregnant woman and the baby kicked you? It was kind of like that: I was riding home and the experience was like a metal (rod?) leg kicking the inside wall of the engine. I made it home several miles and there it sits.
Old 06-25-2008, 05:50 PM
Luis CBR1000F's Avatar
Default RE: doesn't sound good
Is the oil level correct? also check for some chain adjustmnet or a loose bolt on the fairing.
V's,
Luis
Old 06-26-2008, 06:47 AM
GILL's Avatar
Hopefully its not anything serious like a connecting rod. Take it to someone who can listen to it. If its terminal, you might not want to start it anymore so that you dont do any permanant damage to the case. Throwing a rod is not good. Although, these engines dont have atendancy to do that. It could also be a number of other things too. Did the enginge sound or run different just before you heard the noise? How many miles on the bike? How long since a cam chain replacement?Any oil on the ground? Ccheck the drive train too, that can throw many noises your way too.
Old 06-26-2008, 07:02 AM
Shadow's Avatar
Sounds like a semi-seized chain - try oiling it as a first step......if it's old, replace it.....
if not, let's hope it's not a conrod gone mad[X(]
900cbrman
03-24-2010 07:11 AM
ampfp
04-07-2008 02:22 PM
thertkid
08-07-2007 02:34 PM
cbr_newbie
12-30-2005 11:28 AM
Quick Reply: doesn't sound good
