Does this plug look ok?
Old 05-22-2008, 03:14 AM
Coopz's Avatar
Default Does this plug look ok?
I replaced my plugs today with NGK Iridiums. Just looking at the old 1's that were replaced 10,000k ago.
Are they a bit dirty? Is this a sign the engine is running to rich or is it normal for 10k use?
Not sure if this is the dirtiest, one was even a bit darker.
Old 05-22-2008, 03:45 AM
Shadow's Avatar
Default RE: Does this plug look ok?
Coopz, those plugs could've come out of my bike - running a bit rich, but fine.......rather that, than too lean.....
Old 05-22-2008, 04:18 AM
MarkR's Avatar
They should be all the same mostly (goes without saying), that looks a bit dry
Shadow1- How did you survie the last three days without the forum, you must have been devoed..
Old 05-22-2008, 05:28 AM
Shadow's Avatar
Nah, Mark, I just worked on my bike, and did all the things I should've done since December 22....in between doing the "work" thing.....UGH ! he he
Good to be able to talk to all the fellow members again, tho'
Old 05-22-2008, 07:29 AM
It looks a little rich to me, but not too bad. If you have a jet kit, you can try dropping your needle 1/2 notch by using a shim.
Old 05-22-2008, 07:38 AM
GILL's Avatar
Glad to be back!
Normally a slightly brown plug is the best. White usually indicates a lean mixture while black indicates rich mixture. And well oily...thats just bad.... Plugs should be dry when you remove them. Yours look like itmaybe running slightly rich, but it a typical Cane issue as they all run abit on the rich side from the factoryandis just fine, and like vl5150 said, you could have a jet modification.
Off to tackle my CCT....
Old 05-22-2008, 09:04 AM
weekendrider's Avatar
Coopz what fuel do you run
Old 05-22-2008, 09:43 PM
Coopz's Avatar
ORIGINAL: weekendrider
BP 95 normally, sometimes Ultimate but that was $1.70 a litre the other day D:
Old 05-23-2008, 06:17 PM
MarkR's Avatar
I found that standard fuel is best, E-5 seams quite good, but been told I shouldn’t use it
Old 05-23-2008, 06:36 PM
DragonCBR's Avatar
Hi all
Glad the forum is Back !@ For the lug i would say a bit rich but othe than that fine, if you look iside any haynes shop manua they have a page with photos of worned plugs and whats it means, too reach, not correct eheat range etc.., they might have it on their site.
Hey gill how is the weather in your part of the country , here cold one day warm the other already did more than 3500kms ghis year!
http://img140.imageshack.us/img140/4331/pic0008ei4.jpg
pipedcbr
12-29-2010 12:25 PM
sean_k
05-12-2010 05:52 PM
Shadow
04-09-2008 02:20 PM
grim129
07-30-2007 08:48 PM
allnath3
11-05-2006 12:31 PM
Quick Reply: Does this plug look ok?
