Disc Shims- no one ever mentions them
Old Feb 8, 2011 | 01:34 PM
  #41
Sprock's Avatar
Wow , good bit of education there Dave .....never knew that ....now I consider myself
informed thx.
Oh and thanks to Unky Pee Pee too
lol
Old Oct 18, 2011 | 01:52 PM
  #42
reborn biker's Avatar
got the same problem with mine ,the shims are squashed out all over the place ,the only purpose they serve is to stop corrosion between disimilar metals and possiblty a little insulation between a hot disc and the hub ,am very tempted to try a few thin fibre washers instead as most need replacing and the discs are as new except for the fact one looks warped but am sure its because its not pulling flat to the hub,you can get an awful lot of fibre washers for 25-30 pounds and probably do the same job when compressed
Old Oct 18, 2011 | 02:20 PM
  #43
HenryM's Avatar
Grease proof paper would probably do the same job. I'm sure there's many other materials that would also do the job quite well as long as they stand up to getting wet. I think the conclusion from this thread is that they're not necessarily needed. THe genuine product is well conceived though and will do the job well.
After having my wheels painted last year I didn't replace them and have no shims fitted between wheel and disc. I haven't noticed any problems with this. No vibration or judder.
Honda want both arms and both legs for the privilege of buying their genuine parts. Sometimes you've got to, sometimes you don't.
THanks for digging this thread out of its grave. Perhaps it needed a breather.
Old Oct 30, 2011 | 01:23 PM
  #44
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Hey:
Well a lot things have been stated about the shims and I am sorry I missed all the fun in between in this thread, but the main reason most all Honda motorcycles have a fiber shim gasket between the wheel hub and rotor is they are anti squeal/noise reduction. They have been added one way or another to many models since 1978 in one form or another.
They are a nonreasonant fiber but most any fiber or gasket material of like thickness will work just fine.
Dub
Old Oct 31, 2011 | 05:03 PM
  #45
HenryM's Avatar
Much appreciated Dub. A voice of sense at bloody last!
Old Oct 31, 2011 | 07:46 PM
  #46
Bugkiller's Avatar
July 2014 ROTM
Thumbs up damping shims
Hi,
thought I'd throw my two-pence worth in
They are shims to prevent rattle but they are made of paper like textile to absorb any miniscule surface tlerances between the two metal surfaces. having one missing would create a 'gap' causing possible vibration and 1 floating bolt hole.
When fitting new discs do not forget these
As for twins, here are a couple with damping shims
Rick
Old Nov 1, 2011 | 01:54 PM
  #48
Default the twins
do those twins come for left and right hand? think my right hand is getting worn!
whatever has been fitted to mine certainly does not seem standard as it looks about 1.5 milimetre thick and is not like a paper or gasker material ,will "have it off" over the winter and probably replace with a decent more suitable material ,i think what appears to be a slight warp in the front left disc is probably caused by the material not compressing evenly for all bolts as too thick,at around £2 a time for a paper washer,honda parts does seem a bit pricy to replace the lot ,when there are so many practical alternatives,if anyone has and unused one ,would like to know the dimensions of the original part so i can prepare some replacements ready for refitting ,..........spoke to the doc about maybe getting a younger woman ,he said it could prove fatal ,,,well so what !,if she dies ,she dies ,but what a way to go!
Old Nov 2, 2011 | 03:30 PM
  #49
Bugkiller's Avatar
July 2014 ROTM
Smile left & right hand shims
[quote=reborn biker;1110694]do those twins come for left and right hand? think my right hand is getting worn!
Here are the ones you need for left and right hand, colour coded for reference - either colour on either side but don't mix them
Attached Thumbnails Disc Shims- no one ever mentions them-bikini-girls-2-.jpg
Old Nov 6, 2011 | 04:27 AM
  #50
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
Originally Posted by Bugkiller;1110495
As for twins, here are a couple with damping shims :icon_razz:
[IMG
http://www.umnet.com/pic/diy/screensaver/7%5Cblack-bikini-twins--73343.jpg[/IMG]
Rick
Totally Photoshop magic - but used in a useful way.
