Coolent leak
RE: Coolent leak
Does the cooling system allow the coolent to be drawn back into the system when it is cold, or does the overflow just retain "extra" coolent? I had it out for a good ride today after replacing the two hose clamps on the rubber part in the picture. All seems well. I dont have a way to pressure test it, but I might have a friend at a garage who might have one. Thanks forthe advice!
RE: Coolent leak
That three way fitting is plastic and with age deteriorates. First sign might seem to just be a leaky joint repaired by tightening the hose clamp. Then it starts again because the fitting has become mushy.
That happened on mine at about 70,000 miles. I suspect it's an age and heat cycle thing, both contributing factors. Hope that helps.
