Compressing fork springs
Old 06-10-2010, 09:29 AM
hawkwind's Avatar
Question Compressing fork springs
Hi there guys,
I'm going to be rebuilding the front forks (yet again!!).
I've managed to find a pair of brand new fork tubes for the job this time at a bargain price.
Harry .T. Hamster gave me a set a while ago and though I used genuine Honda seals they have started to leak again so I can only think the tiny amount of corrosion they had was enough to break the new seals . Can't imagine why else they would be leaking again , unless I put the seals in upside down , any thoughts ?
Any way I was wondering if there is an easier method of compressing the fork springs when reassembling , easier than me trying to compress it by hand while my daughter slides in the shim ? Any tips will be greatfully accepted
Cheers .
Old 06-10-2010, 11:08 AM
TimBucTwo's Avatar
When you put the seal in, was the open side with the spring showing placed down?
Any corrosion can hurt the seal. The tubes need to be polished smooth.
What I did on reassembly was to back the nut off and then slide the shim under and then tighten the nut. It is still a bitch. At least you had help, I didn't.
Old 06-10-2010, 12:13 PM
VeryMotley's Avatar
I am about to do this. I thought my brakes were leaking, but it is my fork. The right front brake is well lubricated. Glad I didn't find out the hard way.
Sooooo, I think you should do a write-up with pictures.
Pretty sorry way to get you to show me how, I admit it.
Good luck,
Patrick
Old 06-10-2010, 12:28 PM
hawkwind's Avatar
Good luck,
Patrick
There is a thread in the how-to section , take a look Patric , it's pretty easy really .
Old 06-10-2010, 12:37 PM
VeryMotley's Avatar
Cool, thanks. Good to know. I have to order them, I guess I should get the dust covers as well, May be OEM.
Bassman
07-07-2010 08:44 PM
bigape
05-24-2008 07:34 AM
land_warrior.rus
07-11-2007 03:09 AM
davethepom
11-15-2006 01:32 PM
Dstudebaker
11-28-2005 09:10 PM
Quick Reply: Compressing fork springs
