Fork Springs for a 90
Now that I have my '90 1000F on the road, I noticed that the front forks seemeda little soft for my weight (a little over 230 pounds). So, I have been combing ebay to find a set of progressive springs. I found a set for the 87-88 Hurricane and a set for the 93-96 1000F. Are the springs between the 90-91 model and the 93 model that different? Will the 93-96 springs work in my 90? So long as they are the same diameter and length, I would guess that the would work. As I recall, the real differences between the 90-91 model and the 93-96 was the linked braking system (so the rotors and calipers are totally different) and the upper fairing was a little pointier. Other than that, they look the same. The 93 doesn't have inverted forks.
Anyone know the answer to this?
Have a look at "quick suspension question" on page 4 of the posts - may help you.
Otherwise, try adding 10ml of fork oil to each leg - will firm up a bit......
Also -"fork springs - which manufacturer ?" - posted by Malbojah on 28th April, and "Incredible long fork springs" by R1000 on 8th Dec 2006.....
ORIGINAL: Shadow1
I actually got up with Sonic and they have the 1.2kg/mm in stock. I plan to order some next week.
But after reading some of the other posts on replacing the front fork springs, I am wondering if the rear will suck after I get the front sorted out. I wonder if fox or someone makes a replacement rear shock.
Ohlins do shocks for the 87/88 and 89 on, but not cheap !!! Here's a link
http://www.harris-performance.com/we...mp;CatalogBody
