chain tools
Looks nice, but wouldn't an angle grinder or a Dremel work just as well ?(did for me, but then I'm from Darkest Africa), and we don't have access to all the good stuff- 80 bucks seems like quite a lot......? Maybe the ideal thing for Marcsabb( hi Buddy), and his Honda camchain........
ORIGINAL: Shadow1
In case you use a clip-lock, there is no need for the tool.
Many racers use clip-locks on the track where the bike is inspected ever so often, but even then the clip-lock is to be secured by a few wounds of steel wire and silicone glue to meet track regulations. I would not use a clip-lock on a high powered fast bike.
Thats the one, in the comments onit thay say you should grind the side of thepin when removing or you could break the pushing tips. It cost me 110usposted. I will try it out on a cam chain very soon.
ORIGINAL: GILL
Is this the one?? Let me know how it works out as I was looking a the same one..........
[IMG]local://upfiles/23307/B201747F62FC4B3E9F6B965BFF7D6E06.jpg[/IMG]
Two words of caution. Don't overdue the staking. They only need the slightest of a mushroom to retain. And on the big drive chains don't try to push the pin out without grinding the head first. Too hard on the press pin and can damage it. Good practice not just with this tool but any tool you get.
