Cbr1000f 1990 fork oil amounts in each leg....?
I also installed Progressive springs. I think they are a little shorter but Progressive gives you the proper spacers.
What is the best cleaner to clean inside the fork tubes? Disk brake cleaner OK? Simple Green? Also measured only 300ml of old fluid (per fork) plus or minus a few drips here and there on the garage floor. Haynes say 409ml, what can I expect from having the proper amount of fork oil?
Hi Obs,
Personally I wouldn't use anything chemical to clean the inside of the tubes, any residue will just contaminate the new fork oil.
As for oil quantities, both old and new, I just followed the directions in the Haynes manual and measure from the top of the fork tube. After all, you wouldn't do an oil change on the engine without checking the level on the dip- stick would you?
Do the progressive fork springs make that much difference to the handling?
I have been considering getting some but wasn't sure how much of a difference they would make to the handling.
Which springs do you recommend?
I would stay away from progressive springs and get the actual spring rate you need. I used sonic springs and if you go to their website they have a tool to enter bike weight type of riding and it gives you a recommended rate. I love mine but can't compare as I never rode stock.
Hawkwind,
Thanks for you input, I just replaced the oil and I always check the dipstick too. Help me understand why the manual tells me how much volume, 409ml, to use yet further down it talks about a measured distance. If I put in the proper volume, what's the point of measuring? If the measurement is wrong, should I add or remove volume thus it wouldn't be that "409" anymore, but would then be a proper measurement. This is the first time I have done this and I just want to do it right.
Hawkwind,
Also if the fork takes 409ml, then you know how much oil you'll need to go out and buy.
.......I'll say no more lol
