Carb Sync
Old Mar 31, 2007 | 12:22 AM
  #21
Default RE: Carb Sync
I tell you, if there is a way to adjust those floats, or their level, I didn't see a way. The entire body of the float is plastic, not exactly an adjustable type of material if you know what I mean. As for how it's attached, it has a pivot shaft that goes through the float (seen at the very top of photo) and slides through 2 posts. The height of the posts are not adjustable, and the only other attachment point is where it hooks to the Float Valve, and that part is not adjustable either. I didn't attempt to make any adjustments to the carburetor while it was apart. I put everything back in exactly the same way it came out (minus the dirt and grime naturally).
I meant to add a photo of where I left the hoses for future sync jobs. I'll edit the post and add the additional photo if I can. If not, I'll add here.
Thanks for the complement.
Old Mar 31, 2007 | 12:37 AM
  #22
Well, it looks like 5 is the limit for here, so I'm including the following photo here. The is where I've left the vacuum extensions that I attached to each of the ports on the intake manifold. I've temporarily placed an adapter that came with my Carbtune in place of the screw that plugs port #4. I'll replace it later with one like on port 1-3. Each hose has a plug on it with a white adapter piece in the end of it. There is a blue tie wrap holding them all together so they don't fall down below the carbs. The last photo shows the white "T" adapter I installed in the vacuum line that goes from port #1 to the petcock vacuum actuator on the fuel valve. This way I don't need to worry about manually attaching some kind of tool to generate a vacuum so the fuel flows.
[IMG]local://upfiles/10297/C342734D7D6F45DCB6C9F12E8BB7812A.jpg[/IMG]
[IMG]local://upfiles/10297/0EE36B4309944470B65C11DF3A4D074F.jpg[/IMG]
Old Mar 31, 2007 | 02:18 AM
  #23
Stray Cat's Avatar
I also gave some thought to attaching tubing like you did so I can just hook the gauge up and go. But alas I was lazy and wanted to get out and ride, so I didn't. Next time I do a sync I'll install the tubing.
Thanks for the pictures, they're worth and thousand words!
Old Apr 11, 2025 | 12:36 PM
  #24
Honda-fan_Kortrijk's Avatar
Hi DRam and everyone
I also own a 1991 Huricane and the manual I have is for a 1993, so there's some differences in the type of carbs, and I can't figure out how to connect the sync tubes.
If you would have an illustration from your manual or perhaps some pics on how and where to connect the tubes, I would be very gratefull.
Thank you.
Claude
Old Apr 11, 2025 | 02:00 PM
  #25
Thank you.
Claude
You are replying to a very old thread. Most of the members are long gone.
Your best bet is to start your own thread, including pictures of your setup.
Old Apr 11, 2025 | 06:10 PM
  #26
rockpool's Avatar
Thank you.
Claude
the sync tubes go on the head not the carbs. Find the vacuum line from the petcock, the others are similarly located.
Old Apr 21, 2025 | 04:09 AM
  #27
Rockpool, thank you for the reply.
Next question is about the adjustment: I read 3rd carb is the master and can't be adjusted, but all 4 carbs have equal amount of crews. Or is there a vise I can't see?
compster
F2 Tech
29
Jun 5, 2012 12:28 PM
scottiekarate17
Jul 24, 2011 03:47 PM
dakers0010
Sep 15, 2010 09:23 PM
camaropower
Mar 31, 2009 10:23 PM
chrisf
Aug 4, 2006 11:15 AM
