Carb jetting questions
Old Mar 16, 2012 | 11:18 PM
ganzey's Avatar
Default Carb jetting questions
well my 96 cbr1000f has been in desperate need of some new jetting. it has yoshi pipes on it, and just sputters a little sometimes and has a hard time keeping a solid RPM, just bounces a lot. bike has good compression, vacuum, new plugs, new K&N air filter, and good fuel. i have cleaned the carbs, and also rebalanced them. i have a feeling that it is running a little lean because no matter how hard i ride it i still get ~50mpg.
so what kind of jet kit would i need? any idea on how much they cost? ive never been too savvy with the technical side of carbs, just mechanical. i was thinking maybe #135 jets and #45 pilots? does that sound about right?
thanks.
also is there a write up on this? i looked and cant find one. i have done some carbs before where you have to count the number of turns when you take the jet out so you put i back in the same, or do you just screw them all the way in?
also how bad will this affect fuel economy?
Old Mar 16, 2012 | 11:46 PM
outlawfox13's Avatar
From my own research jetting carbs can be a difficult job. Altitude, exhaust, and air intake all take a part in jetting carbs, though I am sure there are some folks on here who have their cbr's jetted with your set up and it may help. But just swapping main jets and pilots may not help, you may need to shim your needle as well. I have found dynojet makes a good kit(used it on an old GS750) and are fairly easy to install. I believe they make a stage 1 jet kit for our bike. Good luck.
Also are you just bench syncing them or are you using a carbtune or similar?
Fuel mileage stock is around 40 mpg if memory serves me. I get 29-33 my bike is jetted, but for the life of me I cant remember the sizes. And our jets just get screwed in till tight.
If I get a chance this weekend I may pull one of my carbs apart and see what jets mine are and what not. I do have to put my new chain and sprokets in too.
Old Mar 17, 2012 | 01:11 AM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Hey:
From where you live, unless Northern Western side 126-128 mains 130 max 40 stock slow should be fine, this should be plenty on normal premium fuel. You will need more fuel (bigger jets) if you use more than 10% gasohol. (Unless it is a Cali model)
What are your plug readings at full throttle, top gear, almost white is ok (like new) , with a slight tan if you can't do a WOT run.
Mileage may suffer, depends on gearing. 50 mpg is good expect less after jetting changes.
Jets tighten till very snug, do not overtighten, also install a fuel filter. if already have one make sure it is clean.
hope this helps.
good luck
Dub
Old Mar 17, 2012 | 06:28 AM
ranchome's Avatar
Dam, I get ~ 35mpg with stock everything. Love to see 50.
Old Mar 17, 2012 | 08:13 AM
Ok, I did some searching in my old posts, and found that my jets are #124 main jets and #40 pilot jets. Good luck!!
Old Mar 17, 2012 | 10:01 AM
ganzey's Avatar
Originally Posted by CBR1988
Hey:
Dub
you know, i didnt even bother to check the fuel filter, ill change it out this weekend and see waht happens.
well, thats what scares me, it has got to be running lean
Old Mar 17, 2012 | 07:38 PM
Have u done plug chops?
hot83chevy
F2 Tech
Apr 17, 2022 09:41 AM
gxsretr
Sep 24, 2009 05:54 PM
MofoSachem
Oct 10, 2005 04:50 PM
mhcbrf2
Mar 28, 2005 03:59 PM
