carb Jets
Old Jul 8, 2006 | 06:03 AM
VeryMotley's Avatar
Default carb Jets
I have been cleaning carbs for what seems like ever and i still am not able to get one of the jet sets out of the carbs; the others came out no problem. I havn't torked them; I didn't want to ruin them. Does anyone know how to get the smooth jets out. Do they screw out like the others? or is there a trick?
Thanks again[sm=burnout.gif]
Old Jul 8, 2006 | 10:39 AM
R1000's Avatar
Default RE: carb Jets
There are two jets per carb in the float bowl that can be removed. It is the main jet, which reminds of a round nut on top of a brass tube, and another jet which looks like a 2 inch long brass tube. Both of them will unscrew counter clockwise. Is it the same jet on all carbs you cant remove, or just one jet in one carb? I remember that all jets in my carbs where quite hard to remove, so one has to use a well matching screwdriver/wrench.
Old Jul 8, 2006 | 01:22 PM
slowpoke's Avatar
ORIGINAL: VeryMotley
Do you mean the jet needle? Or are there caps over the pilot screws?
Old Jul 8, 2006 | 03:51 PM
VeryMotley's Avatar
Ther are 3 brass things that look like jets. 1 is 2 pieces- came out easily. 2nd had a slot for a flathead screwdriver. The 3rd is smooth. no slot no bolt head just a cylinder with a hole. I think this is the one R1000 mentioned.
ORIGINAL: R1000
Yes same jet on all 4.
I havn't gotten through this one. Maybe the hole is too small. Not sure.
Thanks again for all the help,
Patrick [sm=burnout.gif]
Old Jul 8, 2006 | 05:04 PM
R1000's Avatar
The one without slot and without head is a factory pressed in unit, which should not be removed. While you are in the float chambers, also remove and clean the fuel mesh filters (nylon) above the float needle seats.
Old Aug 22, 2006 | 01:05 AM
VeryMotley's Avatar
Hey thanks I just found the last post. I am still getting used to the features on this site. I will have no trouble finding posts I have contributed to. I am going to pull them again so I will look for the filters. Do you ahve to remove the carbs to adjust the inner carbs? #2 & 3? I cannot see how to do it while it is running
Thanks
kerosene
F3 Wanted
Feb 25, 2011 10:08 PM
cwalsh600f2
F2 Tech
16
Mar 15, 2010 08:56 PM
Steve-o
May 19, 2009 07:14 AM
Sand.Man
Nov 7, 2007 11:50 AM
VeryMotley
Jul 8, 2006 04:43 PM
